Old 12-22-2014, 04:26 PM   #1
jtinpdx
Build sheet bummer
After learning on this forum, that some trucks still have their build sheets under the seat, I went to look for it. My truck seems like a true survivor with a rebuilt engine. Found most of the build sheet and was able to put it back together! But it's not my VIN. Must be a swapped out bench seat. Bummer!
jtinpdx is offline   Reply With Quote
Old 12-22-2014, 04:56 PM   #2
leftybass209
leftybass209's Avatar
Re: Build sheet bummer
That isn't ideal, but cool no doubt. At least it confirms your truck may not be as original as you thought; and still, it doesn't make it any less cool.
leftybass209 is offline   Reply With Quote
Old 12-22-2014, 05:10 PM   #3
68350
68350's Avatar
If it makes you feel better, I found a couple build sheets in a 71 that we had. 2 of them were for the truck and one was for a one ton dually. The 71 was a short box 2wd
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 12-22-2014, 07:47 PM   #4
davepl
davepl's Avatar
Mine was stuck on the front of the box behind the cab, so there's a chance that your original may still be there.
I didn't find it until I pulled the cab because I'd never heard of it being there. You can probably peek in from the top or bottom. It was stuck to wet original paint, so hard to get off.
- Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-31-2014, 11:24 AM   #5
Keith Seymore
Keith Seymore's Avatar
- Dave
Just doubling back to this thought, since I didn't get a chance to comment earlier:
Build sheets were affixed to the front of the pickup box for the same reason as the front of the cab: to inform the assembly line workers what option content that box required.
What might not be obvious (until one thinks about it) is that the pickup box and cab went through the paint shop together, on one body carrier, but with enough space to allow the cab back and front of the box to receive full (or almost full) paint coverage, as shown below.
In the photo below the cab/box have been through the ELPO dip tank but have not yet had the color coat sprayed on.
Photo credit: Jeff at 73-87.com, via GM
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-22-2014, 07:54 PM   #6
leddzepp
Moderator
leddzepp's Avatar
You have a Fremont truck so there is a good chance there is another one somewhere in the cab. The build sheet was supposed to be thrown away at the end of the assembly line, but a lot seem to have made their way into Fremont trucks. It does not necessarily mean your seat has been swapped out. Others have also found build sheets that do not match the truck on what they thought was untouched and original.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-22-2014, 08:01 PM   #7
Lee H
Lee H's Avatar
Is your VIN a Fremont truck? If so keep looking. My Fremont build sheet was under the tar paper, under the floor mat, near prefect condition.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-22-2014, 08:23 PM   #8
68350
68350's Avatar
Look inside the cardboard gas tank cover too. Good chance one may be there
Old 12-30-2014, 05:33 PM   #9
factorystock
factorystock's Avatar
Unfortunately build sheets were never designed to be permanent, but they did contain much more detailed info than the SPID. Build sheets list selling dealership and build dates to name a few. Is anyone out there re creating build sheets with the correct type paper and font?
factorystock is offline   Reply With Quote
Old 12-30-2014, 08:21 PM   #10
Keith Seymore
No, probably because that level of specific detail per truck only exists on the build sheet, and the format varies by model year, final assembly plant and assembly station (ie motor line vs chassis line vs trim line vs final line).
1979-1986
1986 - 2019
Old 12-30-2014, 06:50 PM   #11
michael bustamante
michael bustamante's Avatar
mine had three correct ones and one that didnt belong to my truck. 2 in the seat and one taped to the gas tank. found that when i removed the cardboard cover.
1967custom
michael bustamante is offline   Reply With Quote
Old 12-30-2014, 10:04 PM   #12
jocko
jocko's Avatar
While it is a nice to have, it's certainly not a requirement for proving an original truck. Matching SPID VIN, Frame VIN, and GVWR tag VIN are the important ones. I had TWO build sheets under my seat, neither one was the correct one. Musta been the late shift in Fremont... Ha. Nice truck in your pics, show us more please! Always interested in CustomD's as they may be hidden Highlanders... Parchment door panels anyone?
Old 12-31-2014, 07:09 PM   #13
jtinpdx
Here are a couple more pix. Just finished getting a stock used tailgate sprayed to match (sorta) and put on a sport bumper and hidden hitch. What do you think? I can post some more if you like.
-Jeff
Old 12-30-2014, 10:51 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm told Flint built trucks are unlikely to have build sheets in the cab or elsewhere...anyone know of a K5 that's had a build sheet in the cab?
