08-20-2003, 11:37 AM | #1 |
Radiator overflow tank
I recently bought a '69 with a 350/400 combo. The PO had installed twin
electric fans on a new Heavy Duty 4 core radiator and also installed a overflow tank. My question is does the overflow tank have to be at the same level as the radiator cap to allow the fluid to siphon back into the radiator? Right now it is below the cap and the overflow tank stays full but the fluid level in the radiator is rather low. Thanks.
'69 C/10 Short Wide 350/400/AC/Tilt/Tach |
08-20-2003, 11:44 AM | #2 |
CCRider
No vacuum that the radiator creates as it cools pulls it back. Most likey you have the wrong radiator cap on it...a system with an overflow tank require a cap with second seal to create the vacuum.... or there is a leak in the system allowing it to suck air
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
08-20-2003, 01:21 PM | #3 |
I'll check the cap and for leaks. Thanks!
08-20-2003, 03:42 PM | #4 |
Get a radiatior cap for an 85 chevy truck.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
08-20-2003, 04:50 PM | #5 |
anybody have any part #'s? cuz i need one of those radiator caps also
68 short step, 406/700r4, 9" w/discs. |
08-20-2003, 05:21 PM | #6 |
Just go to any parts store and ask for a radiator cap for an 85 chevy pickup. Don't need the part number. Heck Walmart might even have one.
I just checked the one I have on my 71 and there isn't a part number on it. I just bought one for an 85 chevy.
08-20-2003, 05:29 PM | #7 |
there were 2 diff part #s and they looked exactly the same
08-20-2003, 05:57 PM | #8 |
I made a phone call. One part number should be for a cap with the pressure release lever, the other part# doesn't have a pressure release lever. Both are 16# and either will work.
STANT w/PRESSURE RELEASE 10331 STANT REGULAR 10231
08-20-2003, 07:15 PM | #9 |
i'm running a 80's big block radiator
