Old 12-25-2014, 03:22 PM   #1
Wrcampbell
Led Bulbs
I just got some 1157 led bulbs and went to install. i have had alot of problems making them twist and lock into the sockets. Have anyone else tried these bulbs and did you have any issues getting these into the sockets? I have broken two of them off at the base. Any suggestions or ideas?
Wrcampbell is offline   Reply With Quote
Old 12-25-2014, 04:58 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs down Re: Led Bulbs
Are you talking about these? I ended up throwing them in the trash. I never could get them to work correctly.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-25-2014, 05:05 PM   #3
Wrcampbell
Re: Led Bulbs
Not like those. smaller with alot more leds. They work fine once you finally get them in the socket. found them on ebay. They just dont want to twist into the socket. What you using on the big red now?
Old 12-25-2014, 06:50 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Led Bulbs
I have the real LED panels in the back and front parking lights. I have the side markers LED too.
Old 12-25-2014, 08:57 PM   #5
Roostboy102
Roostboy102's Avatar
Re: Led Bulbs
I have had this problem on motorcycles. The problem is, you're bottoming out on the flared part before it's low enough to lock in (at least that's what I figured out after trial and error)!
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 12-25-2014, 10:32 PM   #6
Wrcampbell
Re: Led Bulbs
I'll give Tommy's Truck Parts a call about those panels. They probby have an outlet for them.
Old 12-26-2014, 09:01 AM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: Led Bulbs
Tommy does have the panels but of a different kind. Mine I bought from a member here many years ago.
Link for you.
http://67-72chevytrucks.com/vboard/s....php?p=5393945
Old 12-25-2014, 10:33 PM   #8
Wrcampbell
Thumbs up Re: Led Bulbs
I'm gonna try working on the contacts on the bottom and try the bottoming out thought! Thanks
