Old 12-25-2014, 11:11 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Clutch linkages
1974 c10
The truck came in as a frame only no cab. I put on a cab I had here and converted it from an automatic cab (well it had the automatic brake pedal and mount on it when I got it , but there was a hole in the floor that would work for the clutch pushrod)
So I went on ebay and bought what appears to be a 73-80 brake/clutch pedal assembly. There is a stud atop the mount as well as one on the clutch pedal. There are two kind of eye things and a spring that go in between those studs which it took forever, but I finally got the spring on there. I also found the rod that goes between the Z bar and the clutch pedal. When I put the clutch in it slams against the floorboard and does not return unless I pull it up manually..
Is there another spring I am missing or something and if so where does it go? pics? Are there springs on the Z bar?
Any help or diagrams and part numbers would be great Thank you !
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-25-2014, 11:38 PM   #2
craig113
Re: Clutch linkages
There are 2 springs. The one you put in and two outside the truck between frame and the shaft assembly, and the push rod return spring.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 12-25-2014, 11:45 PM   #3
old Rusty C10
Re: Clutch linkages
do you have pics?
Bob
I hate cancer!!
Old 12-26-2014, 12:49 AM   #4
craig113
Re: Clutch linkages
parts manual images for you
