Old 12-30-2014, 03:08 PM   #1
Bare64
Bare64's Avatar
Front Discs will not engage
Searched here, Googled, bleed and re-bleed the system, made sure proportional valve lines are correct (they are) and still I can't get the front disc's to pressure up, rear brakes work fine. One thing that keeps coming up is the heim rod end at the pedal so I extended it out as far as I felt safe doing so, only about 5 threads left. I am thinking that if I do the modification by moving the hole on the pedal up one inch that all I will accomplish is engaging the rear brakes quicker. Anyone know off the top of their head what the eyelet size and thread size of the joint? Any help or hints would be appreciated.
Andy
Bare64 is offline   Reply With Quote
Old 12-30-2014, 03:47 PM   #2
blown240
blown240's Avatar
Re: Front Discs will not engage
Do you have the correct master cylinder? The disc drum masters have a large side and a small side in the reservoir. Im pretty sure the Discs go to the large side, since it takes more fluid to get fill the calipers vs. the wheel cylinders.
Also, do you have residual valves installed?
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 12-30-2014, 04:48 PM   #3
Bare64
Bare64's Avatar
@ blown..........Correct master cylinder, large and small reservoirs along with a stock Chevrolet proportional valve. Why would I need a residual valve, the master cylinder is above on the firewall?
@ Apache....... no clue here, they seemed to have bleed easily enough. How does one tell if they are collapsed internally?
Old 01-01-2015, 07:17 PM   #4
w00dst0ck
w00dst0ck's Avatar
3/16 front
1/4 rear
Smaller lines to disc brakes.
w00dst0ck is offline   Reply With Quote
Old 12-30-2014, 04:19 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check your rubber lines. I had them totally collapse internally and not let fluid pass easily.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-30-2014, 05:23 PM   #6
blown240
blown240's Avatar
I thought that you still had to use residual valve even with a prop valve.
Old 12-30-2014, 06:15 PM   #7
Bare64
Bare64's Avatar
I think it should be fine with the master cylinder being above parallel to the brakes themselves.
One thing weird is the brake pedal feels fine until I start the truck, then it collapses to the floor.
Old 01-01-2015, 03:23 AM   #8
luvbowties
luvbowties's Avatar
Smile Re: Front Discs will not engage
You're right: no residuals needed. See below. "Top Ten Reasons For A Poor Brake Pedal" ESP. the 1st reason shown re: bleeders must point to 12:00 o'clock--which they won't do if left-and-right calipers are reversed. If so, you'll never get the air out of the front.
>> http://www.piratejack.net/index.php?...port&Itemid=20 <<
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 01-01-2015, 02:45 PM   #9
Bare64
Bare64's Avatar
HTH,
Sam
They are more like at 1:00, going to bleed it again. If that does not work looks like another new booster, master cylinder is new and correct.
Old 12-30-2014, 06:20 PM   #10
blown240
blown240's Avatar
I bet you still have some air in the system.
Old 12-30-2014, 06:32 PM   #11
geezer#99
geezer#99's Avatar
Did you change your pedal ratio?
Stock drums use a 6 to 1 ratio, power needs a 4.5 to 1 ratio.
You need to drill a new hole about 1 inch below the brake rod hole on your pedal.
geezer#99 is online now   Reply With Quote
Old 12-30-2014, 07:46 PM   #12
donthekawguy
donthekawguy's Avatar
What geezer said and check you booster.
66 shorty
donthekawguy is offline   Reply With Quote
Old 01-02-2015, 12:37 AM   #13
Mathew21
Mathew21's Avatar
Bare64 I'm sorry if I missed something here but did you just do an upgrade to disc brakes or is this a problem with a brake system that was previously working fine?
If you're a 100% sure you have no air in the system then it sounds like a bad master cylinder. I don't know if your master cylinder is a new or not. But if it is new does not mean it's good. I have a had bad "new master cylinder" I purchased from an autoparts store more than once.
Below is something I copied from another site. I hope it helps explains why I think it sounds like the master cylinder.
1) If the booster stops functioning, the main effect in an otherwise functioning brake system is that the pedal feels as though it is seized up and cannot be moved at all with normal foot pressures. If very heavy pressure is exerted, some small braking effect may be noticed.......very, very hard pedal is usually the result.
2) The master cylinder generally does not leak outside of itself, it leaks internally and the fluid travels back into the reservoir, so usually no fluid will be seen on or under it or lost if it's bad.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-02-2015, 02:19 AM   #14
64shortbox
64shortbox's Avatar
Bare64,
Sorry I didn't see your post earlier. Since you are using a factory GM proportioning valve - did you use that little tool to hold the proportioning valve centered when you bled the brakes? If not you need to remove (unscrew) the switch in the middle of the valve (the plastic thing that the brown wire hooks clips to that triggers the "BRAKE light on a stock GM vehicle). Once you remove that switch you can look down inside and see a slider with a grove or U cut in it. That grove must be held centered when bleeding the brakes or your brakes won't bleed properly. You can re-center the valve by reaching down with a small flat blade screwdriver. From what I understand if you loose say a front brake line the valve will shift to shut off the brake fluid to the front brakes and divert all fluid to your rear brakes. I'm attaching a picture of the little tool. It looks like it's anodized aluminum but it's just made out of plastic.
So remove the switch - center the valve & install the centering tool to hold the valve centered - bleed your front brakes - remove the centering tool - reinstall the - Brake light switch and you should be done. I bought my tool off eBay years ago but I'm sure Napa or another decent auto parts house would have one. Hope this info is of some help to you.
64shortbox is offline   Reply With Quote
Old 01-02-2015, 11:21 AM   #15
Bare64
Bare64's Avatar
Originally Posted by 64shortbox View Post
Bare64,
Thanks, never heard of this but I will purchase one before I bleed them again this weekend.
Old 01-02-2015, 02:30 AM   #16
w00dst0ck
w00dst0ck's Avatar
Interesting. I've never heard of having to do that.
Old 01-02-2015, 01:38 PM   #17
Bare64
Bare64's Avatar
Ok, looking down into the valve after removing the brake switch trigger I do not see any grooves only a flat rod. How do I move the rod without damaging it?
Old 01-02-2015, 06:34 PM   #18
Bare64
Bare64's Avatar
Where did you find the tool shortbox? Even my master mechanic has never heard of nor seen one.
Old 01-02-2015, 08:48 PM   #19
Mathew21
Mathew21's Avatar
They sell it on EBay but I'm not sure where you would find it locally.
http://www.ebay.com/itm/Combination-...-/160856168243
Old 01-02-2015, 10:06 PM   #20
Bare64
Bare64's Avatar
Thanks, ordered one. Not a bad price at all, but I still have no clue as how to get the "groove" back to the center of the proportional valve. Anyone have an idea of how to accomplish this?
Old 01-03-2015, 12:00 AM   #21
luvbowties
luvbowties's Avatar
You asked, "Anyone have an idea of how to accomplish this?"
An above site-- http://www.classicperform.com/TechBo...t.htm#testprop -- given by Palf70step said, modified by me: "5.The lines that are clear must be left open[BOTH YOUR REAR BLEEDERS] and the blocked ones should be closed to cause pressure to build up on that side. Be sure to use the standard bleeding procedures to prevent air from entering the system.
6.Slowly press the pedal with steady pressure[until pedal reaches floor--then tighten your rear bleeders & slowly let pedal up] a number of times until the light goes out[you prolly do not have a light to see--ok]**REMEMBER TO KEEP MC FULL OF FLUID DURING THIS TIME.**; this will center the differential valve. You may also hear a pop come from the proportioning valve. This is the metering valve returning to its equalized position. When the light goes out[again, you may not have one to see], close the bleeder screw. (See fig. below)."
I hope this works/helps. But proceed with caution, 'cause this is "only how I am reading the instructions"--which sounds logical to me. Kinda like when you press pedal with rear bleeders open, it's like you suddenly lost your rear brakes and the valve rushed to shut off the rears & make all pressure & fluid go to front ones. Sound logical to you?
Sam
Old 01-03-2015, 12:35 AM   #22
Bare64
Bare64's Avatar
Sam
Makes sense to me too, had not gotten that far before I ask my question.
Old 01-02-2015, 07:01 PM   #23
Sounds like your rod is not centered, and until you get it centered they won't bleed right.
Pic is what the tool does once the valve is centered.
This may help to get them centered and bleed right
Old 01-02-2015, 08:34 PM   #24
joedoh
joedoh's Avatar
thank you for explaining why I couldnt bleed the brakes on a 1988 mazda pickup about 10 years ago. it had that same type of distribution block and the front discs would just not engage no matter how much I bled them. I ended up replacing the part.
this forum is awesome, I have lost track of how much I have learned here.
Old 01-03-2015, 10:54 AM   #25
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
good info, saved to favorites. thanks to all
Larry
fleetsidelarry is offline   Reply With Quote
