Old 12-31-2014, 12:04 AM   #1
Fldawg
Fldawg's Avatar
copper oil pressure line
hey guys, going back with copper oil line for oil pressure gauge/ just need a couple pics as the best way you ran your lines and how you did it in case you had to repair your line. i.e. coiling of line, thanks in advance for the replys
Fldawg is offline   Reply With Quote
Old 12-31-2014, 12:39 AM   #2
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: copper oil pressure line
I ran mine out of the factory firewall grommet right above the distributor. The wire then coils down toward the engine and then screws into the block. member LocDock sells a new replacement if you are needing to repair yours.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-31-2014, 01:52 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Thanks Richard.
Here is a thread I posted with the measurements and bending instructions for the line too...
http://67-72chevytrucks.com/vboard/s...d.php?t=613238
LockDoc
Leon
Old 12-31-2014, 12:29 PM   #4
Fldawg
Fldawg's Avatar
thanks guys my old one when i got the truck was mangled so i replaced it with plastic tube with vacuum hose around it, now that one is leaking so i decided to go back with copper, thanks again and lockdoc by the way the diagram is great
Old 12-31-2014, 12:35 PM   #5
LockDoc
LockDoc's Avatar
No problem, post back if you have any questions....
LockDoc
Leon
Old 12-31-2014, 12:44 PM   #6
midniteblues
midniteblues's Avatar
great write up's loc doc.
when i ran my oil line i slid a rubber vac hose over the whole length of the copper tube just too help protect it from damage.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-31-2014, 01:56 PM   #7
LockDoc
LockDoc's Avatar
Thanks,
I have seen a few of the lines with the hose on them. I think I have a couple in my parts stash that I removed from trucks over at the salvage yard.
LockDoc
Leon
Old 12-31-2014, 02:08 PM   #8
midniteblues
Originally Posted by LockDoc View Post
Thanks,
LockDoc
all the oe sbc oil lines i've ever seen all had rubber on the coiled part then a union before entering the firewall.
I should've used a union for ease of engine removal. perhaps i'll ad it at a later date.
one cant deny the one peice soild line though.
I wont use the plastic stuff anymore...its just cheap
Old 12-31-2014, 02:39 PM   #9
bollybib
bollybib's Avatar
This is a pic that I found on this site a couple of years ago. It allegedly is original oil pressure tubing that was being offered for sale on the Parts Board. I used it as a model when I repiped my oil pressure tubing.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 12-31-2014, 03:04 PM   #10
davepl
davepl's Avatar
Mine looks mostly like the one right above, but mine's a big block so it's in a different spot. I wonder if that's what the connector is for in the middle... universal on the one side and engine-specific on the other perhaps?
Either way, I always wondered about the union and am glad to see it's normal.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-31-2014, 05:05 PM   #11
LockDoc
LockDoc's Avatar
Yes, the connector in the middle is the union. The union uses the compression sleeve nuts, the same as both ends of the line.
LockDoc
Leon
