01-01-2015, 05:43 AM | #1 |
ScottieB's 69' c10 in Gatesville, Texas
Hey guys, I bought this truck about a year ago and then I got a drive train for it from a 79' Corvette - 383 stroker with a built th400 - from oil pan to carburetor was included, but not the front accessories or exhaust.
I'm still debating on getting a th700r4 for it though... As I don't really plan on racing it. I'd like the gas mileage boost when in OD. So I had the enjoyment of hunting down a working set of pulleys and brackets etc from the junk yard that would work with what I want to do. So, I got the truck up and running - then it wouldn't stop very well ... replaced the whole brake system and added in a brake booster and got some 20" wheels to put on it. So it brakes, great! Well ... then it had issues getting above 40 mph w/o wobbling all over the place! I had the enjoyment of replacing tie rods, pitman arm, the idler arm, and all 4 ball joints, then had the truck aligned (with shims, which the shop hated). I then had to hunt down a power steering bracket and pump and hoses and install those onto the truck. I had to modify it for my headers, but it works ... for now. The engine leaks, so now I'm going to pull it, strip the paint and repaint, then reseal the engine and stick it back in - but while it's out, i'm going to paint the headers and the inside of the engine bay, then rewire it with an EZWire kit. I have some rocker panels and floor pans on order, a chrome instrument panel with all working instruments, glove box, glove box handle and lock, fan switch, grill, and a few other things that need replaced / installed. So... one thing at a time! I need to replace the heater core because it's cold out - I don't know if it's good or bad, but at $25 ... i'd rather have peace of mind. My album: http://67-72chevytrucks.com/vboard/a...p?albumid=2092
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 01-01-2015 at 03:17 PM. |
01-02-2015, 03:28 AM | #2 |
Re: ScottieB's 69' c10 in Gatesville, Texas
Parts list that I need:
69: Fix wobble on column and enable use of left turning signal correctly Replacement tach 3 3/8 (medium) for null gauge Clock for null gauge (small) Fix crappy wipers Radio and speakers kit Gas tanks under bed + route them correctly (from suburban) Spare tire mount under rear of bed Sub box behind seat after gas tank removed (current gas tank works fine) Driver Side Kick panel. Mine is rusted Fix Heater / A/C issues Courtesy Light kit ($20) Headlight warning buzzer ($10) Daytime Light kit ($25) Figure out the backup light issues figure out oil pressure and temperature gauge issues (missing oil pressure tube kit 49") LED headlights New lenses after paint job Ducts for air system 4 under the hood lights Parts ordered, but not installed: Glove Box interior box Glove box handle Floor pans LH RH Rocker Panels LH RH Grill (71-72) Chrome Instrument Cluster Heater core EZ Wire 20 circuit kit Repairs needed: Install a 100-amp inline fuse to hot starter wire + route positive ground on side of frame instead of loosely hanging by headers - prior to engine re-installation Install 2x in line fuel filters Move Alternator to driver side to allow proper factory A/C to be installed w/o custom hoses Install EZ Wire 20 circuit harness Replace Heater core Install heater switch and make heater work Inspect ducts and replace as needed Install A/C correctly and charge A/C Replace floor pans, rocker panels, and fix small rust in inner driver front bedside Bedliner in cab floor, firewall above trans E-Brakes don't work, slack in line still --> Sandblast, primer, and paint truck and airbrush custom stuff onto it Repairs done: Reseal + repaint engine & headers / change fluids / flush radiator of gunk Install Drivetrain and make truck run, get front components for engine and year specific sensors, wire / hook up engine etc Whole new brake components (drums) / system + brake booster + master cylinder Whole new steering system (tie rods, pitman / idler arm, U/L ball joints, alignment, power steering pump added / flushed air from gear box) 2 1/8" Lug bolts swapped + 1.5" Wheel adapters added + 20" wheels added Inner bed sandblasted and bedlinered. Glove box lock installed Fan switch to enable use of heater / AC fan installed Install LED's into cluster instead of old outdated dim lights Bedliner in Bed New suspension all around (coils + shocks) New power steering gear box Fixed 86' power steering pump with a 1/4" steel bracket to keep it from wobbling. Installed courtesy light casing. Front End Alignment. New 1 ton radiator / fan shroud and brackets.
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 05-15-2016 at 10:14 AM. |
01-02-2015, 09:22 PM | #3 |
Sandblasting
So, I've started sandblasting the inside and top of bed so that I can put bedliner on it.
There's not a lot of *bad* rust in the bed except in the driver front, all of the other rust is very minimal compared to it. After the bed is done, I'll do the cab under the seat and behind the gas tank. I did learn something very, very important today ... If you want to re-use sandblasting medium - make sure your surface isn't wet ... There goes 2 bags of blast, but that's ok ... it's only $8 a bag. I was using 20-40 grit blasting medium and a non pressured canister
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 Last edited by ScottieB; 01-06-2015 at 09:53 PM. |
01-06-2015, 09:52 PM | #4 |
I went ahead and sandblasted the tailgate today and then put in my first coat of bedliner onto the whole inner bed and top of the rails
It took a while, no joke!
69' Chevy C10 383 Stroker / TH400 275 55 r20 Wheels Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=654751 |
01-12-2015, 10:17 PM | #5 |
I got some LED's in to replace the crappy stock bulbs in dash. In person they are a LOT brighter. These are easily 10x brighter than stock ones!
I also sandblasted the floor of cab to see how bad the rust was under the paint ... and surprisingly not too bad! I have the floor pans and rocker panels ready to be put on, I have to order a driver kick panel that's rusting out, and maybe a passenger rear cab thing, i'll have to see after I take the cab off. I covered the floor in spray bedliner, I'll go back and put real bedliner on the floor when the weather is warmer this weekend.
05-15-2016, 10:06 AM | #6 |
It's been a while. I got a new job that takes up more of my time.
I have put on new wheels and brand new tires. Replaced the power steering gear box and all new suspension (coils and shocks) I have rebuilt the engine - it was leaking like a siv. It now has a 1 ton radiator and fan shroud. And a new battery. Sadly, not much else. I have paint for it, but the time is just not there to do full on projects except on the weekends.
