Sound / heat mat
What is the best stuff for the money? Want to use some on my 81.
Re: Sound / heat mat
If you want spray on http://www.lizardskin.com/ stick down would be http://www.dynamat.com/ or http://www.designengineering.com/cat...tical-products has a few options.
![]() Join Date: Jul 2014
![]() Join Date: Jul 2000
I like RAAMmat BXT for sound deadening (panel vibration dampening). It works as well as DynaMAT Xtreme and costs a lot less.
http://www.raamaudio.com/categories/...Foam-Products/ For a heat barrier, lay some of this on top of the RAAMmat: http://www.competitionproducts.com/T.../#.VKbY99LF98E It's essentially blue jean fibers with a foil backing that will lower your floor temperature substantially.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#6 | |
#7 | |
I liked it better when it came in rolls.
I had a member on another forum suggest adhesive asphalt flashing. He said it works almost as well as Dynamat and is about 1/3 the price.
http://www.lowes.com/pd_124018-81326...7C1&facetInfo=
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#9 | |
http://www.lowes.com/pd_495919-46086...ber&facetInfo= |
#10 | |
It's rubberized asphalt, not butyl rubber. There is a difference. Edit: I clicked on the wrong link. What you linked is butyl rubber, but damn it's small. Seems like it would take a while to lay down. |
That was just an example. I'm sure there are other options
![]() Join Date: Oct 2014
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
http://www.homedepot.com/p/UltraTouc...8?N=5yc1vZbedf I used both of these products. It was far cheaper the the Fatmat or DynaMat before installing my new carpet. |
If anyone reading is shoestring budget looking for a temporary fix I've found that a big piece of memory foam under the seat soaks up enough sound to have conversations at highway speed even when you have worn out door seals and a whole in the floor. doesn't help on the heating side of things though...
could of had an air conditioned honda but, I'm hard headed and have standards ![]() |
So i used to preach about Fatmat, and the similar types of stick down insulation. My 77 Pro street( 6-71 blown sbc) thats bagged and body dropped. I had 3 layers on the floor, my firewall was done, and my doors inside and out. while it did good for sound, i melted it, and my carpet was stuck to it. it seeps up through the edges. I also did my 97 crew cab , as it is my tow rig. Also melted through on the floor and actually got so hot, that my wife couldnt put here feet on the floor as it would burn her. We were towing through nevada in 105 degree weather. and i live in socal where its always warm. that being said, i am now gonna use Lizardskin on my new build. and see how it holds it up to heat. Also on my 77 the inside of the cab was always really hot. never needed a heater at all..
