01-03-2015, 03:56 PM | #1 |
Do k20's sit higher than k10's
my question is will a k10 with a 4 inch lift on it sit the same height as a k20 or k30 with a 4 inch lift. Im really only focused on if it will sit the same as a k20 but a k30 is a bonus. Thanks!!!!!
01-03-2015, 05:24 PM | #2 |
Re: Do k20's sit higher than k10's
A k20 yes, k30 no. Assuming all 3 have the same tires, wheel width, and are on level ground.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
01-03-2015, 06:33 PM | #3 |
The 10 and 20 frame are the same height and width, but the 20 uses thicker steel. The 30 is taller (and I think thicker too). C and K frames are somewhat different as well.
1973 C20, 350/350 |
01-05-2015, 11:08 AM | #4 |
so your saying that there will be no height difference between the k10 and k20...only the k30?
01-05-2015, 02:39 PM | #5 |
I don't know. I know the rear axle tube diameter on the 20 is larger than the 10, which would contribute a little bit to ride height if all else is equal. I don't know whether the heavier duty springs that the 20 has increase ride height at all vs the 10.
1973 C20, 350/350 |
01-05-2015, 01:54 PM | #6 |
Robert Olson Transport
that's what he is saying the K 20 I had had bigger tires on it than my k10 so it sat a couple inches higher I liked it higher
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-05-2015, 02:11 PM | #7 |
Thanks guys! im deciding on weither 6 inch 35's or 4 inch 33's. What do you guys think? is 4 inch 33's too small on a k10? its going on a daily driver thanks
01-05-2015, 03:50 PM | #8 |
Here are some dimensions from the 1980 Chevy truck vehicle info kit from https://www.gmheritagecenter.com/gm-...tion-kits.html I picked 1980 just because it's in the middle of the 73-87 year range ... other years should be similar.
Ground clearance (front / rear) K10 = 7.4" / 7.1" K20 = 8.8" / 7.2" K30 = 8.3" / 7.8" Overall height (ground to top of cab roof) K10 = 71.9" K20 = 73.9" K30 = 74.7" (or 75" for bonus/crew cab) These dimensions are for "standard equipment" trucks with 6-cyl engines and no load. |
01-05-2015, 04:07 PM | #9 |
I.m.o. a 4" lift on a k10 would sit at a k30 height stock. K20 would sit about 1 1/2"-2" higher than the k10. That said skinny 35's will (for the most part, such as humvee 35" take offs) clear stock k30 suspension. Starting with the k10, I would do 6" and 35". Basically a k30 with a 2" lift. With either combo the tires will fill the wheel wells about the same. Don't forget to consider drive line angle of the 6" as well as possible gear change needed with the 35's. Most likely you can live with whatever the stock gears are with 33's.
Matthew |
01-05-2015, 05:42 PM | #10 |
My truck sits with in a margin of error of a K10 a new neighbor hood guy I meet has.
I built a light duty K20 with 3.42 gears, and 265/75/16's. Which on PYO's measure 32 3/4 inches. I have bull bolt ons, and the truck was very peppy with the stock 350. I have since added the low gear planatary, and it is more peppy. You really notice it when I loaded the truck up a few times. I carb is shot as it leaks are internally, and gets real annoying on the tune. Still has given me a average of 13-14 highway up or down hill going 65/70. City likely 8 or so, but how do you difine city. My tires are falken wildpeaks e rated with about a 450 tread ware. So depending on how far you commute I would watch tire selection, and height. Paying for nothing gets old quick if you never get to use it. Last edited by Ziegelsteinfaust; 01-05-2015 at 05:50 PM. |
01-05-2015, 08:47 PM | #11 |
Ray beat me to it and with facts! Thanks for that info Ray!
Matthew |
Tags |
k10 |
