Old 01-06-2015, 12:01 PM   #1
BigSix
Is my bench seat stock?
Driving my truck means looking out of the very top of the windshield. Also, getting in the steering wheel seems very close to the bench. Of course I'm still in rebuild mode for my truck so I haven't put many miles on it but would like to determine if my issues stem from an elegant but incorrectly sided bench?
BigSix is offline   Reply With Quote
Old 01-06-2015, 12:01 PM   #2
BigSix
Re: Is my bench seat stock?
Also you can see a part of my sweet wood pile out of the passenger window!
Old 01-06-2015, 12:42 PM   #3
Lugnutz65
Lugnutz65's Avatar
Yes, that seat appears to be fcatory correct for the 1963-66 models. Probably has been recovered since it looks nice. Yes, many people have commented in other posts how close the steering wheel is, even with the seat all the way back. Some remove the gas tank and gain some extra leg room that way.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-06-2015, 01:07 PM   #4
VictoriaHardware
VictoriaHardware's Avatar
That is the correct seat frame. As noted, it has been recovered. The height of the bottom cushion IS taller and therefor closer to the steering wheel, so during the recovering process someone added more padding. The factory seats aren't known for their comfort, so they were likely trying to correct that.
VictoriaHardware is offline   Reply With Quote
Old 01-06-2015, 01:35 PM   #5
MitchFloyd
MitchFloyd's Avatar
I'd like more info on that very interesting selector above the rocker panel...
https://www.facebook.com/groups/388285118009662/
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 01-07-2015, 01:00 PM   #6
earl84
MitchFloyd, that is a selector lever for trucks equipped with saddle tanks.
Bigsix, don't know about your seat, but the steering column looks stock. I have seen where some guys cut out a section of the steering shaft, slide the column forward a bit and reweld it. I put in a steering column from a motorhome and essentially did the same thing while installing. There are 4 bolts that hold it in place and the clamp on the engine side of the firewall. The clamp is a no-brainer, but I did have to cut and reweld those 4 nuts, but it really wasn't too difficult, and the payoff in driving comfort was well worth it. It does make getting your gauge cluster out impossible without dropping the steering column, though, but again there's only 4 bolts. Takes very little time or effort.
earl84 is offline   Reply With Quote
Old 01-06-2015, 02:07 PM   #7
PGSigns
PGSigns's Avatar
Looks to be a good 2 inches taller than a stock seat. You may be able to have the foam redone in the bottom of the seat and re use the same cover. Back also looks a little thicker than stock.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-06-2015, 02:10 PM   #8
PGSigns
PGSigns's Avatar
The first page of this thread shows some stock seats and how much thinner they are.
http://67-72chevytrucks.com/vboard/s...d.php?t=329412
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-07-2015, 07:40 AM   #9
Coltronist
I believe your seat is an original c10 seat, but I don't believe it was original for your truck. The Deluxe or custom model seats have padding in them like yours, and the conventional seat was just leather on wire.
As for your steering wheel, maybe the previous owner placed a shorter steering column?
Coltronist is offline   Reply With Quote
