Old 01-06-2015, 12:26 PM   #1
gasmn1620
tranny question
I currently have a 350 trans and I want to put an overdrive tranny in. What will bolt right in with no issues and which one do you guys recommend?
gasmn1620 is offline   Reply With Quote
Old 01-06-2015, 02:43 PM   #2
77c10
77c10's Avatar
Re: tranny question
I put a 700R4 in mine. It bolted right up and I did not have to shorten the driveshaft. With some TH350's you will have to shorten it. The only fabrication I had to do was make a new crossmember but you can buy one for not very much.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-06-2015, 03:08 PM   #3
GRADYS Performance
GRADYS Performance's Avatar
Re: tranny question
A TH700R4/4L60 transmission is the closest to a direct replacement for the TH350 transmission. Differences are driveshaft length, crossmember/mount location, torque converter, dipstick, TV cable and linkage at carb and torque converter lockup control. I would suggest using a TCI #376600 kit for the converter lockup. The transmission needs to be 82-92 that uses a TV cable, 93 and later have to use a computer to operate.
GRADYS Performance is offline   Reply With Quote
Old 01-06-2015, 05:12 PM   #4
gasmn1620
Re: tranny question
Thanks for the info guys
Old 01-06-2015, 06:07 PM   #5
Just call me Sean
Just call me Sean's Avatar
Re: tranny question
There's a long and short tailshaft 350. One uses the same length driveshaft as the 700R4.
Another difference to watch for is electric or mechanical speedometer. You want mechanical most likely depending on the year of your truck, but an electric can be converted with the proper parts.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
