Old 01-11-2015, 03:00 PM   #1
Mr Chevy
and son
Mr Chevy's Avatar
Cast Iron nose Starter Bolts 1971 K10 350 4spd
Hello everyone, first off: Go Seahawks!!!
Ok now with that out of the way. I have a 1971 Chevy K10
Previous owner put the automatic trans alum nose starter on the truck and it isnt starting correctly. I purchased the proper cast iron nose cone which i was told Im suppose to have for a standard trans but the alum bolts up to the block the cast iron nose bolts horizontally to the bell housing. I need to know what size bolts to purchase to be apply to install my new correct starter.
Thanks in advance for your help.
1970 C10 8ft Fleetside
The build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=289628
1986 GMC 3500 2wd CrewCab Dually 454
1994 Chevy 2500 2wd Ext Cab 8ft bed
Mr Chevy is offline   Reply With Quote
Old 01-11-2015, 04:39 PM   #2
ray_mcavoy
Re: Cast Iron nose Starter Bolts 1971 K10 350 4spd
You'll need two 3/8"-16 x 1" bolts, one 3/8"-16 x 1-3/4" bolt, and three 3/8" split ring lock washers.
The two shorter 1" long bolts go through the 2 un-threaded holes in the starter nose and screw into the bellhousing. The one longer 1-3/4" bolt goes in from the opposite direction ... through an un-threaded hole in the bellhousing and screws into a threaded hole in the starter nose.
ray_mcavoy is offline   Reply With Quote
Old 01-15-2015, 09:08 PM   #3
Mr Chevy
and son
Mr Chevy's Avatar
Awesome, perfect. Thanks alot for the info Ray huge help. Thanks again.
The build thread:
Old 01-16-2015, 08:00 AM   #4
MARKDTN
I thought the bolt-to-bellhousing starter was just for 6-cyl?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-16-2015, 05:55 PM   #5
ray_mcavoy
You're welcome! Glad I could help.
They were used with both 6-cyl and V8 engines. Chevy cars stopped using the bellhousing mounted starters in the early 60's but GM pickup trucks continued to use them up to 1972.
Old 01-18-2015, 02:58 PM   #6
Mr Chevy
and son
Mr Chevy's Avatar
The only reason im even trying to put the bolt to the bell housing cast iron nose starter on is because im having a starter problem where it cranks but sometimes stops cranking and spins freely like it doenst engage correctly. I checked out AutoZone and their computers say automatics use aluminum bolt to block and manuals use cast iron bolt to bell housing. So I assumed my problem was related to having the wrong starter not simply a defective starter. Does anyone else on here have a 71 with manual and use the alum starter that bolt upward to the block like every other chevy i have ever had?
The build thread:
Old 01-18-2015, 03:16 PM   #7
Mr Chevy
and son
Mr Chevy's Avatar
I just took my old starter off. I dont think my bell housing has the holes for the cast iron nose. I think I may just have a defective starter and need to replace it with another alum bolt to the bolt starter.
The build thread:
