Old 01-12-2015, 08:30 PM   #1
Black66
Muncie M21 4spd replacement for a Saginaw 441, fitment/dimensions questions
I just blew my Saginaw 441 transmission last week . Been trying to find a Muncie M21 to replace it with.
My question is: How much of a change will the placement of the rods/linkages be on the Muncie? I have a floor Hurst shifter that I know is compatible with the M21, but I'm not sure where it will come up through the floorboard when I have it attached to the Muncie trans.
Black66 is offline   Reply With Quote
Old 01-12-2015, 08:35 PM   #2
pimpston65
pimpston65's Avatar
Re: Muncie M21 4spd replacement for a Saginaw 441, fitment/dimensions questions
Is the M21 that "rock crusher" ? I heard those were some beasts of a trans, hope you get one, I'm just rolling a Muncie 3speed...
pimpston65 is offline   Reply With Quote
Old 01-12-2015, 09:16 PM   #3
Black66
No I think the "rock crusher" is the M22.
Old 01-14-2015, 09:33 PM   #4
ND-1965C10
ND-1965C10's Avatar
It is really far back on the factory bench. I can get better pics in the spring but am running the setup. I have a custom stick where am using two hursts bolted together to push further forward and up higher. I need to do more work in the spring as I hit the seat with second and fourth.
ND-1965C10 is offline   Reply With Quote
Old 01-14-2015, 10:31 PM   #5
Greg63
Enjoy your truck
Greg63's Avatar
I had an M21 in my '63 for years. The shifter pretty much hit the bench seat in 2nd and 4th with the seat moved all the way back. If you have short legs it will be an issue.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 01-14-2015, 10:57 PM   #6
66Submarine
66Submarine's Avatar
I put my Saginaw 4 speed in my father's '66 when the Muncie M20 that was in there had an issue; IIRC the only thing I didn't reuse was the reverse shift rod.
BTW, the shifter for a '55-'57 Bel Air with a bench seat works (at least with the seat back).
From the Hurst FAQ:
I’m trying to install a Hurst shifter into my ’55-57 Chevy, but it seems like the stick is going to be under the bench seat.
For ’55-57 Chevys, Hurst uses a special stick shaped like a large “C” to clear the original bench seat. Due to the extreme angle that the stick comes out of the mechanism, it was not possible to make it a bolt-on stick. It is welded into the mechanism, like the 65-70 Mustang shifter. The stick is not available separately, and can only be ordered with the shifter under part # 3913780.
They still sell them separately: http://www.summitracing.com/ga/parts...8620/overview/
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
