Old 01-14-2015, 10:32 AM   #1
chase@ridetech
chase@ridetech's Avatar
RIDETECH Coilovers on a 73-87
I have been planning to put the front kit on my 85 Suburban and just haven't found the time yet, but a few of my customers have purchased our 63-72 kit for their Square fender trucks.
One of my customer sent me some pics back of his. He is running 18" wheels and Stock Spindles. We initially sent him the correct ball joints for his year of truck and he did have to Drill 2 additional holes on our upper coilover mount but we will make that change on our brackets going forward.
So with stock spindles this is what a square fender will look like.
chase@ridetech is offline   Reply With Quote
Old 01-14-2015, 06:10 PM   #2
c-man405
Re: RIDETECH Coilovers on a 73-87
So if I'm understanding this correctly it is a 63-72 kit on a 73-87? If so what does the kit include?
Thanks carter
c-man405 is offline   Reply With Quote
Old 01-14-2015, 06:36 PM   #3
chase@ridetech
Thanks carter
Sorry for the confusion. We make a coilover kit for the 63-72 trucks, but had not made a kit yet for the 73-87 trucks. This customer bought our early c-10 kit and we put the correct balljoints in to fit on his 85.
the Front Kit includes tubular upper and lower control arms, coilover mounts and coilovers.
Old 12-13-2015, 11:44 PM   #4
74partsrunner
How low can the ride height be for the suspension to work properly? I am going to do coilovers (most likely your strong arm kit) on my 74. I am going to section the crossmember 1.5" and run a 2" drop spindle. I am shooting for about 2" of tire tucked with a 28" tall tire.
74partsrunner is offline   Reply With Quote
Old 12-14-2015, 01:07 PM   #5
RootBeerFXS
RootBeerFXS's Avatar
subscribed
RootBeerFXS is offline   Reply With Quote
Old 12-14-2015, 06:43 PM   #6
bbbc10
Diggin The SquareLife
Depends on ur wheel and tire combo also backspacing of the wheel inner fender clearence ect
bbbc10 is offline   Reply With Quote
Old 12-15-2015, 02:12 PM   #7
chase@ridetech
Doing a drop spindle and sectioning the crossmember should put you there within an inch. You will have some adjustment on the coilover as well.
Old 12-16-2015, 03:31 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Any plans for Ridetech to produce a raised crossmember?
That's the downfall of the 60-87 trucks when you want to drive them low.
Keith
Convert to disc brakes.
Old 12-18-2015, 10:19 AM   #9
chase@ridetech
As of right now its not on the drawing board but if that changes I will be sure to share.
Old 12-14-2015, 04:49 PM   #10
Tom
driving is in my blood
Tom's Avatar
With 3" spindles the stance would be perfect. Very interested.
Old 12-15-2015, 10:11 AM   #11
74partsrunner
I am running 15x8 truck rallys in the front with a 275/60r15 tire. I have the stock spindles with djm lowering control arms and air bags now. I have it sitting at the ride height I like. I am switching to coilovers because I want adjustability/performance without having to deal with bags. I just want to make sure I can get the suspension angles (strong arms) in the ranges they were designed to operate at and be at the ride height I want.
Old 12-15-2015, 10:01 PM   #12
bbbc10
going to need a smaller tire
Old 12-15-2015, 10:26 PM   #13
74partsrunner
Why would I need a smaller tire(sidweall, width,ect)? It fits with room to spare right now at the ride height I want?
Old 12-15-2015, 10:56 PM   #14
74partsrunner
This is where is would like the front, the rear needs to go down another couple inches.
Old 12-16-2015, 02:39 PM   #15
Shugalou
Shugalou's Avatar
That looks perfect IMO - has a dropped look but still retains all functionality.
Will this work with the stock rally wheels with no issues?
What is the pricing on this kit?
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 12-18-2015, 10:17 AM   #16
chase@ridetech
Stock wheels should have no issues.
The front upper and lower Shockwave/ Coilover Strong Arms with the Coilovers will start out at $1950.00 for the set.
Old 12-17-2015, 08:27 AM   #17
Jrgunn5150
Subscribing
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 12-17-2015, 08:38 AM   #18
74partsrunner
I have the stock wheels on there now with aftermarket arms and there are no issues. The ball joint part of the control arm looks to be smaller on the ride tech arms so it should be ok. I guess I won't know for sure until I get the arms and drop spindle installed.
Old 12-17-2015, 07:08 PM   #19
BIG SWOL
interested..... puttng 22.8.5 on front hopefully bagged however still would like the info for the coil over set up
BIG SWOL is offline   Reply With Quote
Old 12-18-2015, 04:18 AM   #20
Drewkimble48
subscribing
Drewkimble48 is offline   Reply With Quote
Old 12-18-2015, 10:47 AM   #21
Shugalou
Shugalou's Avatar
Dang 2gs US means close to 3gs CAD by the time we get bent over on dollar, duties and shipping. Looks like a great kit
Old 12-18-2015, 09:51 PM   #22
74partsrunner
Is there any (more) pictures of the RideTech coil over kit installed on the front of a square body?
Old 02-09-2016, 10:03 AM   #23
chase@ridetech
Ill get some more pics up soon.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
Old 02-13-2016, 07:56 PM   #24
G8DAN
G8DAN's Avatar
Are the shocks adjustable? Like your HQ shocks?
G8DAN is offline   Reply With Quote
Old 02-15-2016, 12:08 PM   #25
PowerdbyChevy79
PowerdbyChevy79's Avatar
are yall planning on making a crossmember with rack and pinion I love the ridetech but truth be told I dont like having to use the unisteer setup if I used the ridetech.. its the only reason I haven't pulled the trigger on the coilover kit yet..so im patiently waiting..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
