Old 01-15-2015, 10:21 AM   #1
6768chevylover
6768chevylover's Avatar
Wheel spacers?
I need to get 1/4 inch wheel spacers for the front wheels to clear wilwood brake calipers. I was wondering if I do that would I need to buy new lug nuts that have a shank on them or be able use the ones I have? I have Camaro Rally wheels on my truck.. Also if I do need lugs with a shank on them do I need to drill the holes out bigger? Hopefully some one has ran into this problem.. Thanks -Mike
6768chevylover is offline   Reply With Quote
Old 01-15-2015, 10:44 AM   #2
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Wheel spacers?
if the current camaro rally wheels do not need a shank style lug, you're probably ok with re-using them, provided you can still get at least 5 turns on the lugs after you add the spacers. Plus, if you get a good hub-centric spacer, there will be no room for the extra shank in the wheel stud holes
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-15-2015, 11:07 AM   #3
4oldcars
4oldcars's Avatar
Re: Wheel spacers?
I had the same problem with 5/16 spacers. Nearly. With the spacer on, the center hub ring does not seat leaving the wheel to be held in place by the lug nuts only. I was uncomfortable with this and took the spacers off. Perhaps I was being over cautious.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
