![]() Join Date: Aug 2014
Photo or advice to mount radiator overflow
I know this seems petty but where do you guys mount the aftermarket radiator overflows? I have one left over but it seems there is no where to mount it considering where the battery is. Need in a good visible spot where Sis can see it easily and look like it might belong there. A photo or two would be good.
![]() Thanks, Andy
1964 Bare to the Bones |
Senior Enthusiast
Re: Photo or advice to mount radiator overflow
I have what looks like a similar tank. Mine in located on the driver’s side next to the radiator ahead of the alternator:
![]() ![]() I no longer have inner fenders, but the tank was in the same place back when I did, although maybe a bit higher.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Thanks Mark, good location for it but my Unisteer PS Reservoir is located in that spot. The overflow "spout" also points out to the Passenger side under the hood.
![]() May just relocate the battery if I don't come up with something.
Driver side.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
That is my issue, I already have that spot full ^^^^^^^^^^^^^^ see above
60-66 Nut
What about mounting it in the corner where the radiator and battery tray meet?
