Old 08-22-2003, 11:26 AM   #1
ssuper_nova_71
Removing brake drums
Hey guys, I have the HO72 rear end in my truck (69)
How do you get the drums off? I took the tires off, and could not remove the brake drum.
Am I missing something?
ssuper_nova_71 is offline   Reply With Quote
Old 08-22-2003, 11:30 AM   #2
rickspickuppart
make sure you back off the brake shoes there may be a ridge and hanging up on it
rickspickuppart is offline   Reply With Quote
Old 08-22-2003, 11:32 AM   #3
Jwill41
Jwill41's Avatar
I always pry behind it at the top while hitting lightly with hammer at the bottom. They are usyally stuck around the center hole.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-22-2003, 03:31 PM   #4
Canada20
I don't know if they fit our drums, but I assume they would; you can rent a drum brake puller if it's stuck. I'm partial to that 'cuz my landlord owns a rental shop and he lets me use tools for free.
Greg
(oops...just realized it probably wouldn't work 'cuz of the full floating hub...sorry)
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 08-22-2003, 04:12 PM   #5
gmc67swb
gmc67swb's Avatar
DONT FORGET ONCE YOU BACK OFF THE ADJUSTER TO HIT IT SIDE TO SIDE WITH THE PALM OF YOUR HAND. THIS WILL HELP GET THE SHOES AWAY FROM THE DRUMS. LIKE THEY SAID YOUR SHOES HAVE MORE THAN LIKELY WORN A RIDGE INTO YOUR DRUMS CAUSING THE DRUM TO HANG ON THE SIDE OF THE SHOES AS YOU TRY TO PULL THEM OFF.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 08-22-2003, 04:13 PM   #6
oldtrucknut
67-72 truck surgeon
Try striking it with a hammer between the lugs. That usually works for me, but I have also spent hours of beating on a drum that was seized to get it off. Good luck.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 08-22-2003, 04:45 PM   #7
ssuper_nova_71
Well the drums are not locked. I drive it around fine. I just want to check the brakes and the hardware.
I have the floating rear, and there is this big thing either on the drum or in front of the drum.
Well, This weekend i'll try to remove it again. I'll just get the 3 lb sledg hammer and see what happens.
Old 08-22-2003, 05:18 PM   #8
john
member #16
john's Avatar
You probably have inboard drums ,Which means you have to pull the axles and wheel brgs. The drums are on the back side of the hubs on the GM diff. The DANA drums pull off from the front.
john is offline   Reply With Quote
Old 08-23-2003, 09:38 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup, pull the axles out, and don't be afraid to beat the crap out of that drum with something bigger than a 3 pound hammer.
We use sledge hammers on them at work, and the only ones ever damaged were so thin that only a morron would try to use it again.
