Old 01-22-2015, 08:43 AM   #1
Posted
Posted's Avatar
Steering Play
Guyhs, my truck is lifted 4" with a rugged country lift from way back. I have terrible response and noticed the pitman arm linkage that connects to the box is real bad. Must be something I can replace. Also, is there adjustment to the steering box itself to tighten that as well to the column?
Posted is offline   Reply With Quote
Old 01-22-2015, 11:38 AM   #2
Tinkermc
Re: Steering Play
there is a screw with a lock nut made for adjustments. The worn out pittman arm should be replaced also before it breaks at 90 mph and you have no steering.
Tinkermc is offline   Reply With Quote
Old 01-22-2015, 11:59 AM   #3
Posted
Posted's Avatar
Re: Steering Play
Lockout on the pitman linkage? I see that. The actual rubber on this linkage just seems worn. Is that stock?
