01-22-2015, 06:32 PM | #1 |
Interior done lights come on when pressed but not with switch?
Truck is an 05 Chevy 4.8. If you press the overhead light button they come on but if you use the switch next to the headlight switch they don't. All exterior lights work perfectly. Is there a fuse for it?
My names Tye. No Chevy right now |
01-23-2015, 03:39 PM | #2 |
Re: Interior done lights come on when pressed but not with switch?
are you using the push button or the dimmer roll switch?
01-27-2015, 03:29 PM | #3 |
blood type; Retumbo
"Courtesy defeat" activated?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
02-19-2015, 03:44 AM | #4 |
02-19-2015, 12:41 PM | #5 |
The dome override switch. Its part of the headlight switch. Make sure that its working properly. I've seen them get stuck and not allow the lights to come on with the doors.
