Old 01-22-2015, 07:39 PM   #1
cees
cees's Avatar
Need HELP ASAP
Does anyone have the means or know someone who does have the resources to make plates to box my chassis lookin to box under the cab to the bed ( the S part of the chassis) and the rear bed corners. Willing to pay for parts but not gonna pay a arm n leg let me know please
cees is offline   Reply With Quote
Old 01-22-2015, 07:52 PM   #2
mattybilt79
Re: Need HELP ASAP
Can't say for sure but I'm sure someone makes frame boxing kits with pre cut pieces that any welder could put in. Or look for metal fab shops or chassis in your area. If no one on the board speaks up.
85 3+3 with a tee-pee
mattybilt79 is offline   Reply With Quote
Old 01-22-2015, 08:02 PM   #3
cees
cees's Avatar
Re: Need HELP ASAP
I can weld them in just don't heavy shoppes near to make the pieces or they try to "reinvent" the wheel jus wanna box it
Old 01-22-2015, 08:44 PM   #4
speedygonzales
speedygonzales's Avatar
Re: Need HELP ASAP
I don't understand the problem. Buy a sheet of steel, cut strips the right width, weld them in. Welding them the correct way of course. If you have the ability to weld, you should have the ability cut pieces. What's the problem?
Let's assume you don't have a good method to cut the sheets. Then you take measurements and give them to a shop and ask them to quote the cost of the pieces. If it's too high, have them make just a few pieces each week until you get done.
If it's too hard to draw pieces like "S" shapes. Then make templates from cardboard and give them those. Or trace them on paper and give them the drawings so you can keep the templates.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 01-22-2015, 10:04 PM   #5
joecool
Re: Need HELP ASAP
Just take a piece of cardboard and put up against the frame and hit it with a hammer. Frame will make an impression on the cardboard. Could you tell us why you need this boxing of the frame?
joecool is offline   Reply With Quote
Old 01-23-2015, 12:40 AM   #6
cees
cees's Avatar
Re: Need HELP ASAP
Being lazy to be honest been dealing with a lot of **** n just would like someone else to cut the stock jus wanna put it against the frame n weld it got a lot of other stuff to do to the truck m just would like a break
