spindle
I have a 72 1/2..will the spindles from the 81 fit on my crossmember?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: spindle
Not without changing the upper ball joints and outer tie rods.
Re: spindle
if you can give me any other advice it sure would be appreciated...
Re: spindle
Are you trying to change the truck over to a 5 lug?
#5 | |
Re: spindle
71-72 trucks are already 5-lug.
Re: spindle
Lots of parts change info here for drum brake trucks and just compatability in general:
Re: spindle
I have a 5x5 bolt pattern.i need a 5x 4 3/4 bolt pattern..im trying to see what is innerchangable .i have the rims and tires all ready.guys are saying the 91 z28 rotor fits but only on 81-86 spindle.
#8 | |
Re: spindle
But you have to use 81-87 LIGHT DUTY (Belltech 3200) drop spindles, or stock light duty (1" rotor style) oem spindles. And 1992 Camaro 1LE rotors. Might be cheaper to re-drill a set of HD rotors for your existing spindles,...
