01-27-2015, 10:33 PM | #1 |
Replacing Frame Rivets
Has anyone replaced the rivets in their frame and what did you use? I am thinking of using wheel studs because of the splines. Anyone have any better ideas?
01-27-2015, 10:36 PM | #2 |
Re: Replacing Frame Rivets
Grade 8 bolts.
I just gotta get out here and do it, why? Cause nobody will do it for me... |
01-27-2015, 10:39 PM | #3 |
I second grade 8 bolts. It's scary how easily some of these old rivets can break
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
01-28-2015, 04:08 PM | #4 |
Really? I've spent hours removing some of them...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-28-2015, 05:20 PM | #5 |
well, that picture I shown, those were actually chrome steel. I have galvanized ones and the black oxide finished ones, I'll have to double check the box they came in, but I'm pretty sure the black ones are grade 8, can't say the same for the galvanized ones, but I'll check
and I agree on the drilling the rivets out for hours, even after using an air chisel, driving the rest out were a P.I.T.A...... |
01-28-2015, 05:29 PM | #6 |
Lol...so true. I even gave one the 'A-hole of 2014' award.
You remember when drinking too many beers was a bad idea? Me neither. |
01-28-2015, 05:37 PM | #7 |
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
01-29-2015, 08:55 PM | #8 |
Same here. Last time I got frustrated with the grinding and air chiseling, so used the torch and had to add some metal I'd torched away...
Those rivets are tough. They also fit tightly in the holes so replacing with bolts will allow whatever part to move around, regardless of the torque on the bolt. |
01-30-2015, 03:16 PM | #9 |
Just found some interesting info on "Socket Head Cap screws"
Here's what I found- "SHCS DO NOT HAVE GRADES ! ( If someone says it is a Grade 8 or 5 , he is full of it !) They meet the ANSI 1962 standards and are forged and rolled formed from quality steel.They do not have a hardness spec, but do have the strength requirement of 176K PSI. A grade 8 bolt only needs a 145K psi Tensile Strength to meet spec, so those who think that a SHCS is a grade 8, are wrong, because a SHCS is far superior. In fact they are 20 % superior. OK so you now know that SHCS made in the USA are ALL made with superior steel and heat treatment.(probably comparable to a 4140 or 4340 HT steel) and are only available as such." Taken from this website- http://bbs.homeshopmachinist.net/thr...question/page3 look at post #23..... good info here. Ben |
01-28-2015, 08:19 AM | #10 |
yup grade 8 for me. Should be stronger than the rivets.
01-28-2015, 08:33 AM | #11 |
120,000 psi proof load.
130,000 psi yeild 150,000 ,tensile https://www.boltdepot.com/fastener-i...ade-chart.aspx
I just gotta get out here and do it, why? Cause nobody will do it for me... Last edited by Mock1; 01-28-2015 at 08:39 AM. |
01-28-2015, 08:41 AM | #12 |
Correct me of im wrong, but arent the rivits nothing more than cold role thats heated and beated?
01-28-2015, 10:31 AM | #13 |
I've ground off and removed nearly every rivet in my entire frame. I've been replacing them with grade 8 nuts, washers, lock washers and bolts. It gets fairly expensive buying all those bolts a few at a time from the hardware store!
01-28-2015, 11:45 AM | #14 |
I have these "socket head" bolts at my work, that are rounded on the head, and I've seen people take and fill the allen socket with "J-B Weld" and sand and paint them to appear as rivets, just an idea....
Ben |
01-28-2015, 11:53 AM | #15 | |
Instead of getting bolts a little at a time from Ace, or other hardware stores, get a total count and go to a FASTENER store. Price will be much cheaper, most of these places sell hardware by the pound, not the piece.
01-29-2015, 04:13 PM | #16 |
Those socket head bolts appear to be stainless steel. For your frame, most stainless steels are a bad choice because of corrosion caused by contact between dissimilar metals and the lower tensile strength of stainless steel. The bolts won't rust but the joint in your frame will rust more rapidly with a stainless fastener. Better to use a Grade 8 Hex cap screw.
01-28-2015, 01:17 PM | #17 |
Tractor Supply sells grade 8 bolts (and other grades also) by the pound if you have one near you....that's where I get mine.
01-28-2015, 02:16 PM | #18 |
Find yourself a nut and bolt supply store. They will usually beat the prices you find at the hardware stores, particularly on grade 8.
1968 Chevrolet Fleetside C-10 1971 Chevrolet Fleetside C-10 |
01-28-2015, 03:22 PM | #19 |
these are galvanized, but I have regular grade 8 ones in black too.....
01-28-2015, 04:07 PM | #20 |
Nice, they look like stainless. How do you tell the grade on those?
01-29-2015, 09:21 AM | #21 |
I've been getting them from two different AG stores. True Value and orchelins. The Fastenal place will only sell huge full boxes. IE 100 count etc. My next move is going to see about buying bulk assorted grade 8 and grade 5 with a bin.
01-29-2015, 09:55 AM | #22 |
how many did you need?
01-29-2015, 03:01 PM | #23 |
ALOT! haha I know that doesn't help you out much, but I replaced all of my suspension as well as cross members with ECE stuff. I also removed the bed mounts as well as the rear cab mounts. I used 7/16 grade 8 bolts in various lengths. On all of the cross member bolts, I used 1 1/2" bolt, washer, washer, lock washer, nut, in that order. I'm sure its over kill at its finest, however I'm sort of "that guy". I also put in a CPP tubular shock tower/cross member on the rear and ended up using 2 1/4" bolts on that, 6 in total. Those had to be a little longer because of the extra material added from the c-notch. I would safely say that I have over a hundred bucks in grade 8 hardware at this point, and I still have more to go.
01-28-2015, 10:13 PM | #24 |
You will not find me replacing any rivets unless it's absolutely necessary.
01-29-2015, 11:47 AM | #25 |
Those bolts look sweet..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
