01-28-2015, 12:50 AM | #1 |
Shop in San Diego to install LS motor
Hello all,
I am new to the forum and I am looking for a shop in San Diego to install a LS motor into my 1969 Blazer. My current small block 350 is done. Any help would be greatly appreciated. Thanks, Ryan |
01-28-2015, 11:28 AM | #2 |
Boosted Member
Re: Shop in San Diego to install LS motor
I have zero advice for you....but I'm morbidly interested in the quote you get when you find one.
Keep us in the loop.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-29-2015, 03:59 PM | #3 |
I did mine myself 4 years ago, a shop is SD will charge a ton to do this.
I could advise you on a few questions if you feel like tackling it yourself. Not hard at all as long as you have some technical abilities and can turn a wrench. |
01-31-2015, 06:25 PM | #4 |
Well I found a guy in San Marcus that would charge $2000-3000 for the just the install of the engine. The price I am getting for an engine swap is $8k-$11k.
72Mike-I am a little pressed for time and space to do the build myself. I do really appreciate the offer though. Thanks |
01-31-2015, 09:37 PM | #5 |
That price you were quoted, I think I should raise MY labor rates from the 60's to at least Y2K prices.....................damn I would have enough to stay retired
01-31-2015, 09:39 PM | #6 |
Did that price include engine and trans, and all fuel parts?
02-01-2015, 02:51 AM | #7 |
meowMEOWmeowMEOW
IMO engine swaps are something that you do yourself, or you don't do it at all unless; its a high-dollar ground up custom build (like a Riddler car or an actual turn key racecar) OR your doing something so radical that no home-hotrodder could attempt it.
Paying a shop to put a used engine into a used truck more often than not, results in getting the least bang for the buck, bar none. A typical LS swap is getting done under $4k, and that usually includes go-fast goodies and custom stuff. Your looking at over twice that for a stock junkyard motor. When something breaks, you have NO idea how to track down the problem if a shop did the work. You can't exactly have it towed to a normal garage if a failure occurs.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-01-2015, 01:28 PM | #8 |
PM me if you are interested in someone in Orange County I know a couple of shops that could do the installation
Pulatoy |
02-02-2015, 09:15 AM | #9 |
RyKramer99,
I am a computer tech, I did my swap in my carport over a 7 month time frame, working evenings after my kids were in bed ( I am a single father also). The only thing I didnt do was the exhaust, I had a guy come out and do the exhaust on a trailer that was a lift kind of thing and he did my exhaust. I had very little help and rented the cherry picker and a few other tools I did not have. The engine and trans cost me about $1000, harness and tune, about $250, exhaust about $200, fuel and misc about $300. You can do this!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-02-2015, 11:55 AM | #10 |
2k to 3k just to install the engine??? I should be doing this for other people and not just myself.
03-04-2015, 05:39 AM | #11 |
CUNNINGHAM MOTORSPORTS is near san diego area. Ls1tech.sponsors. I went there and they had alot of nice cars being worked on including old schools getting ls swaps.
03-04-2015, 10:10 AM | #12 |
Charging that much money for an LS swap seems crazy to me. I did mine in about 2-3 weeks (4-6 hours a day). However I had all the parts that I needed from doing all the research before I started the swap. Converting the harness and intergrading with the existing truck harness was the hardest part.
I also agree with Brew, if something breaks you will know what is wrong and what parts to get. Auto parts stores won't know what to look for. |
