01-28-2015, 10:52 PM | #1 |
Wire looms
Just put new plugs and wires in truck.I would like them to look more clean and neater if possible? What do most ppl do? Open to suggestions and pictures if possible. Thanks!!!!
Zibs71 |
01-28-2015, 10:57 PM | #2 |
Re: Wire looms
Oops got one of cab lol
zibs71 Last edited by zibs71; 01-28-2015 at 10:59 PM. Reason: wrong pix |
01-28-2015, 11:13 PM | #3 |
Re: Wire looms
Try Genuine GM Performance 12495502 Wire Loom Kit. $12.00. looks like this:
01-29-2015, 10:39 AM | #4 |
Re: Wire looms
Thanx Fitz
Will these work with SBC as well. I have a 350 in mine. Just not sure if there's a difference ? Thanx Zibs71 |
01-29-2015, 11:21 AM | #5 |
Re: Wire looms
I used wires for a 75 vette with HEI, and ramshorn exhaust manifolds. Routed them as original with the original stands I got off of GMCPaul.(most any vender will have them) Here's some pics. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
01-29-2015, 11:27 AM | #6 |
70+ ( Old Skool Club )
Re: Wire looms
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-29-2015, 01:13 PM | #7 |
Re: Wire looms
I had fun doing this.
Figure out what you want--then figure out what you are willing to give up to get it. |
01-29-2015, 01:22 PM | #8 |
Re: Wire looms
I did mine under the headers too.... A lot more cleaning has taken place since the pics. Just doing little by little. I got a couple looms at Autozone and made a bracket out of aluminum bar the bolted to the the block on the under side. bolted the loom to it and clipped all in.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 01-29-2015 at 01:28 PM. |
01-29-2015, 06:01 PM | #9 |
Re: Wire looms
looms are from Jeggs. I built the wires from bulk, that way you get just the bend/curve you want to curve around the Rams Horns. I used straight plug sockets. I also cut the risers for the looms from stainless tubing. The tubing and longer bolts bear down on the valve cover spreaders and makes a nice seal. BTW--none of this is my creation--all compiled from all the wizards on this site!
01-29-2015, 06:04 PM | #10 |
Re: Wire looms
detail on the risers and spreaders
