Old 01-29-2015, 06:41 PM   #1
IdahoMan
Exclamation Help: Interior Troubles
Hi all.
I'm concerned about my interior. There are leaks and some bubbling under the carpet by the kick-panel. I've decided I'm going to tackle the entire interior, but I need some advice. For instance: What should be replaced or if it is better off left alone or restored OEM.
Here are pics: (if you need a pic, just ask)
There's some orange in the highlighted pic, that worries me (it's the base of the windshield above the glove-box). My new windshield gasket has always been a problem. Large gaps between it and the body. You can see the water trickle behind the kick-panel. In the last pic, the hole to the right seems to go straight through to the outside. Is it supposed to be like that?
IdahoMan is offline   Reply With Quote
Old 01-29-2015, 06:43 PM   #2
IdahoMan
Re: Help: Interior Troubles
Condensation puddle?
Old 02-06-2015, 11:35 PM   #3
IdahoMan
Alright, it's been raining a lot. That's when that puddle appears.
What's it coming from? Couldn't be the windshield. A roof light?
IM
Old 02-08-2015, 07:40 PM   #4
IdahoMan
Seems the leak is coming from the roof area?
Old 01-29-2015, 06:46 PM   #5
IdahoMan
BTW,
What's the difficulty level of replacing a back window? Mine's in great, original condition, but the chrome is getting very brown/discolored. I'd like to see it new, but maybe I should leave well-enough alone?
I also am thinking of restoring the vent windows. Oh boy..
Old 01-29-2015, 09:19 PM   #6
Your41Plague12
Your41Plague12's Avatar
BTW,
You can replace just the strip itself without removing the window. The corners are a bit of a pain. There should be a tutorial on here somewhere.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-29-2015, 10:14 PM   #7
tucsonjwt
You are not supposed to have that leak, but all 3 squares I have owned have leaked like that at some point. You need to start with the windshield and make sure that you have a rust free opening and all of the sheet metal is flat where the seal fits. I think this is a job for the best windshield shop in your area. They need to pull out the windshield and let you have a look at the condition of the seal area. If you have rust or it is not smooth, then you need to fix that first - a body man job. Most windshield shops will just slap in a new windshield and forget about the condition of the opening.
Also, the discount windshield seals are junk. Precision is supposed to be a good brand, but check with your best installer.
tucsonjwt is offline   Reply With Quote
Old 01-30-2015, 01:43 AM   #8
IdahoMan
Thanks. That's the other issue: Finding the right stuff. OEM in normally always better than Repro so I'd like to keep or restore what I can. If not, I REALLY need to know what brand to go with.
Old 01-29-2015, 11:30 PM   #9
enaberif
Windshield needs to come out to inspect the drain holes and metal flange. You have a leak in the windshield somewhere.
enaberif is offline   Reply With Quote
Old 01-30-2015, 02:47 AM   #10
jetmech85
I had a windshield and back window put in my '86 a few years back. I wanted new one peice gaskets and had a hard time finding mail order ones that were in stock. LMC was the only one that could ship the next day. Reluctantly I bought from them. Turns out both front and rear fit perfectly. The glass installer said my old ones were good and very usable just needing the lock strip replaced but I liked the one peice front and used the new ones. Now I always use the old originals and hardly ever find one that is weathered and cracked. You can easily find black lock strips from '90/'91 Suburban windshield and side glass or purchase new if you want chrome.
jetmech85 is offline   Reply With Quote
Old 01-30-2015, 02:32 PM   #11
IdahoMan
What of that black lining/stuff under the carpet: Should it be replaced? Can it be replaced with something OEM-quallity?
Old 02-06-2015, 11:26 PM   #12
IdahoMan
Same with the carpet. I've heard of ACC. Is there GOOD auto or marine worthy carpets that fit perfect and are durable?
Old 02-09-2015, 09:55 AM   #13
patrickth
Your truck shows every sign of being hit hard at one time. If I am seeing right, the bubbles over paint look like either "fisheyes" or someone painted over water. Do a Google image search on paint fisheye". You are probably best served by doing some excellent detective work and measurements before spending too much money. You could be getting into a money pit. My point being learn more about it before you just go tell some "put a new gasket on" or whatever.
I would like to see some pics of doors closed on a level surface to see if panels, fenders, roof and door actually line up correctly.
patrickth is offline   Reply With Quote
Old 02-09-2015, 02:29 PM   #14
IdahoMan
Think you posted to the wrong Thread Pat. lol.
Old 02-09-2015, 02:48 PM   #15
patrickth
I am not convinced. No disrespect, but that does look like fisheye, it also appears your door striker is moved a lot more than usual. Not sure exactly what the covering is in that area. but looks to me like they used it to cover up an alignment issue.
I have been wrong a lot in my lifetime, but I hold to the old maxim, trust but verify. Alignment and leaks usually mean it has taken a hit in my experience.
Old 03-24-2015, 03:19 PM   #16
IdahoMan
Been raining a lot.
Where the water is coming in here:
(Not the cup-shaped grommet, but right above it in the background)
Old 03-24-2015, 05:30 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
I get some drops too from those upper areas.
But I'd call that pic welding or seam sealer splatter.
I've seen bumps like that scrape right off
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
