Old 02-07-2015, 09:06 PM   #1
ironman3452
ironman3452's Avatar
My 64 1ton panel
Just wanted to introduce myself, I have always loved chevs, and always will, so when I found this panel, I knew it was to be rescued.
I will be the third owner of this 64 1 ton panel, and I do have loads of work to do to get it back on the road, so thanks for letting me join.
ironman3452 is offline   Reply With Quote
Old 02-07-2015, 09:13 PM   #2
65sub
65sub's Avatar
Re: My 64 1ton panel
Welcome! Show us some pictures
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-07-2015, 09:15 PM   #3
ironman3452
64 1 ton panel
so why don't I see any panel trucks here, is there only pickup trucks, just wondering , may need to start up a forum about panels
Old 02-07-2015, 09:25 PM   #4
spacedebris
Re: 64 1 ton panel
top of the page, the burbs and panels are lumped together.
here is a link
http://67-72chevytrucks.com/vboard/f...play.php?f=241
spacedebris is offline   Reply With Quote
Old 02-07-2015, 09:42 PM   #5
ironman3452
Re: 64 1 ton panel
but not all true panels, are burbs, and not all burbs are panels.
Old 02-08-2015, 02:20 AM   #6
Softpatch
Softpatch's Avatar
Re: 64 1 ton panel
yes....but a burb or panel could be a carryall
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-07-2015, 09:18 PM   #7
ironman3452
I will I took the photos with my phone, so I have to down load them, but there will be lots
Old 02-07-2015, 09:37 PM   #8
ironman3452
64 panel
so how do I put pictures here so every one can see?
Old 02-07-2015, 11:36 PM   #9
AcampoDave
AcampoDave's Avatar
Re: 64 panel
On Android, I log in, then click "post reply", or "start new thread", NOT "quick reply". If you are in a quick reply you need to click on "go adavanced". Next click "manage attachments" then choose where you get your pic, then"upload" then "close this window" then post. (the spring pic got posted as I was making sure I told you correctly.)
AcampoDave is offline   Reply With Quote
Old 02-08-2015, 12:23 AM   #10
OldGMJon
OldGMJon's Avatar
Wink Re: 64 panel
click the paperclip at the top of the comment box opened.
When opens press a browse tab and direct it to you picture from there.
Piece of cake...
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 02-07-2015, 10:44 PM   #11
Mathew21
Mathew21's Avatar
Welcome
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 02-08-2015, 02:26 AM   #12
Captainfab
60-66 Nut
Welcome to the forum
Old 02-08-2015, 01:11 PM   #13
ironman3452
ok so here is my 64 C30 panel, I know she looks ruff but to me she is a thing of beauty
Old 02-08-2015, 04:49 PM   #14
Free Candy Inside
I have a 1 ton panel... 63, the cooler windshield years!!! Lol
Free Candy Inside is offline   Reply With Quote
Old 02-08-2015, 04:56 PM   #15
ironman3452
so what did you use to lower it to the ground?
Old 02-08-2015, 05:14 PM   #16
Free Candy Inside
I pancaked the crossmember 1.5"s and then bought a set of Michigan Metal Works upper and lower control arms. I'm using factory spindles and 205/70/15 tires. The crossmember is from a 84 Chevy so I have disc brakes. I also modified the frame under the cab to cut out the spots that hang down lowest. The body is also channeled/lowered on the frame roughly 4"s.
Before all this work I had a stock crosmember, cupped lower control arms, and 3" drop spindles and it would lay frame. But that wasn't low enough for me, I wanted to lay door.
If you click on my name you can probably find my build.
Old 02-08-2015, 06:15 PM   #17
ironman3452
cool I think mine is going to stay the way it is, minus all the rust I will be removing.
Old 02-08-2015, 07:44 PM   #18
spacedebris
Welcome to the 1ton club. You know, I dont know what the production numbers were for these 1 ton versions but so far I have found less than a dozen on the roads. Oh, I see lots of panels, but they are all the 1/2 ton versions. I keep watching but there are definitely not many of these left.
my 60 with the even cooler pig nose hood
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
Old 02-08-2015, 08:16 PM   #19
Free Candy Inside
You're correct, I hardley ever see a 1ton longer version anywhere. I only know of 1 other one that's on the road and bagged. As far as I know, I have the only one that is bagged and lays door. Which I understand isn't everybodys cup of tea. I also have a pig nose gmc hood!
I'm jealous of the diesel you have in yours. I may have to go that route in the future!
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Old 02-08-2015, 08:20 PM   #20
ironman3452
understand and thanks will except the invatation and glad to see I am not the only one here with one
