![]() Join Date: Sep 2007
tach differences
So im just starting to learn about our factory tachs. First question: how can you tell the difference between the 6 and 8 cyl. Tachs?
Second question. Can a six cyl tach be used on a 350 w hei?
1967custom |
Moderator
![]() Join Date: May 2007
Re: tach differences
6 or 8 cyl will be stamped on the back, as well as a part number. They are not physically different.
A 6 cylinder tach will work with your v8, but it will not read correctly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Ok great. Thank you
1967custom |
Ok guys i just got my tach dash. 1967.
The marking is unreadable. Any other way of telling the difference? There seems to be some sort of adjuster screw on top in back
1967custom |
Where are the part #s on the factory tachs? I could really use some help on this one
1967custom Last edited by michael bustamante; 02-14-2015 at 02:47 PM. |
anyone?
1967custom |
The factory part numbers were originally ink stamped onto the back of the tach along with the markings for 6cyl or 8cyl.
GM #6468321 is for the 6cyl gas engine tach. GM #6468228 is for the 8cyl gas engine tach (except medium duty trucks with transistor ignition). GM #6468320 is for the 8cyl gas engine tach with transistor ignition. I believe all of the diesel tachometers in this year range were cable driven so one of those should be easy to identify. Unfortunately, I don't think there is an easy way to ID the electronic tachs used with gas engines if the ink stamped numbers on the back are no longer readable. I suppose you could hook it up to your engine along with a known tach and compare the readings. |
