Old 02-10-2015, 08:18 AM   #1
FamilyBowTie
49 steering column removal help please
After removing the steering wheel and inside brackets, what next?
I see 4 bolts on the steering box just at the bottom of the column, is that what needs to be unbolted?
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 02-10-2015, 01:18 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: 49 steering column removal help please
The column and gear box remove as a unit..from underneath
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-10-2015, 02:54 PM   #3
OrrieG
OrrieG's Avatar
I thought I answered this, pitman arm needs to come off, make location for reinstall, then box is unbolted from the frame and box with column is pulled out of the firewall. This assumes everything inside (steering wheel, shift mech, turn signal, mount to dash, etc.) has been removed or unbolted. If you are saving the stock shaft or relocating to install v8 search to find threads on that.
