Old 08-24-2003, 07:28 PM   #1
mkmiller1
mkmiller1's Avatar
Skid Plate Pic
I read a thread the other day about a factory skid plate. It had stated that his was riveted to the crossmember and others stated that theirs simply bolted to the two crossmembers(transfer and skidplate). Here is a pic of a "factory?" skidplate that I have on my lwb '68 model. I also looked at another '68 about two weeks ago that has the same skid plate. I doesn't connect to the transfer x-member at all and it is riveted to this crossmember.
What do y'all think?
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 08-24-2003, 10:02 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
yours is factory for 67-69, 70-72 mounts under the transfer case and is bolted to 2 crossmembers. if my memory is correct, the 67-69 unit was mounted under the carrier bearing on longbed 4x4s.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 08-24-2003, 11:43 PM   #3
1969 GMC
1969 GMC's Avatar
jerry you are correct, the skidplate goes under the carrier bearing, and I think the skid plate they were talkin about before was an actual RPO code, this is stock (at least from what I've seen).
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-25-2003, 06:47 PM   #4
nu2-72
I have about a dozen of the later skid plates for sale. These are plates that I made to the factory measurements. 8" x 20 1/4" x 1/4" with the mounting holes and the large access hole.
$25.00 + ship if interested. These do not include the crossmember.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 08-28-2003, 07:39 PM   #5
69gmcfleet
My '69 has the same skid plate as mkmiller1 truck does.
Jeff
'69 GMC K2500 LWB, '74 350/SM465/Rockwell T-221, cnD44/ffD60, 3.73 gears, 31" BFG's
(originally had 305ci V-6)
'05 VW golf
'84 HD Sportster XLX
'68 GMC K2500 parts beast
69gmcfleet is offline   Reply With Quote
