02-10-2015, 01:44 PM | #1 |
72 Shoulder Belt Mounting Bolts
Does anyone have a source for 7/16 20 bolts to mount the optional shoulder belts I bought recently? The bolts included in the NOS package are 1/2 13, which are fine for the floor attaching but not for the shoulder of a 72 truck. I'm guessing that they switched to 1/2 13 in 1973. The holes are there, with caps, but are definitely 7/16 20. I am going to try NAPA and a True Value who specializes in agriculture, but I need the high shoulder for the belt to ride on.
02-10-2015, 04:47 PM | #2 |
Re: 72 Shoulder Belt Mounting Bolts
My local autyo parts store carries them in the help section
02-10-2015, 05:11 PM | #3 |
Here you go...
http://www.summitracing.com/search/P...ze/7-16-20-in/ |
02-10-2015, 06:48 PM | #4 |
Getting the 7/16 20 bolts is easy. getting ones designed to attach seat belts is the problem.
The belt needs to be attached and the bolt tightened against the unthreaded shoulder, so the belt will ride on the unthreaded shoulder and not be pinched and not able to move. The picture shows the 1/2 13 bolt that is too big, a 7/16 20 with an unthreaded shoulder, but it is too long (on the shoulder part and will stick out too much. The shorter one has no shoulder. I might be able to use the shorter one by cutting a sleeve wide enough to let the belt hang freely. |
02-10-2015, 06:53 PM | #5 |
A big long explanation with pictures ? Wouldn't it b easier to walk into the aoutparts store buy it and take the proper thing home and bolt it up
02-10-2015, 07:30 PM | #6 | |
The correct grade 8 shoulder bolt is available from Juliano's Hot Rod Parts. PN JU010100. |
02-10-2015, 08:41 PM | #7 |
Same grade 8 shoulder bolt is avialable at the local auto parts store only differance between mine and yours isd you like to spend the extra money on shipping that i dont
02-11-2015, 11:27 AM | #8 |
I would love to find one like the one you picture FITZ, but so far, 3 different stores (NAPA, Agricultural True Value and Home Depot) and I get them only like I pictured. Okay length and no shoulder, or too long with too large a shoulder. Without a shoulder, the bolt has to tighten all the way down and pinch the belt, which needs to swing on the mounting bolt, or too long a shoulder and it will stick out way too far from the cab. I will try some other places in hopes I can find a 7/16 20 with a short shoulder.
02-11-2015, 12:36 PM | #9 |
Take a ride up to daytona i'd b glad to take you to the autoparts store and show you how to find the help section and how to find the proper bolts
02-11-2015, 01:12 PM | #10 |
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-11-2015, 01:43 PM | #11 |
This site also has some ! Look under the Bolts: Specialty You can sellect the bolts you want.
http://www.andoauto.com/mounting.htm
02-11-2015, 02:20 PM | #12 |
Thanks guys. I went to ACE Hardware this morning and bought 2 grade 5 bolts that will work. Any issues and I'll contact the Seatbelt Store.
02-11-2015, 03:02 PM | #13 |
Subscribed!
RP |
02-11-2015, 05:34 PM | #14 |
All installed successfully! I will post a few pictures when I get a chance.
02-11-2015, 09:53 PM | #15 |
Sub'ed also
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-12-2015, 01:07 AM | #16 |
Subscribed, I hope to be doing this before too long. Thanks.
02-12-2015, 02:44 AM | #17 |
Moderator
Pair on the left are the correct 7/16-20 bolts for factory shoulder belts. Bolt on the right is a 7/16-20 from a 67 lap belt. 67 trucks used a 7/16-20 bolt on the floor, and they can be used to mount shoulder belts as all 67-72 trucks have that thread in the pillar mounts. 68-72 floor mounts use a 1/2-13 bolt. You can use any 7/16-20 bolt to mount shoulder harnesses, as it is hidden by the boot and not seen
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-12-2015, 09:57 AM | #18 |
Thanks leddzepp. I was surprised when I discovered the shoulder belt install required 7/16 20 instead of 1/2 13, but I was able to adapt other bolts to mount the shoulders. I would guess the correct bolts pictured are not too common.
02-12-2015, 10:04 AM | #19 |
Those bolts are very common at local autoparts stores you just need to look
02-12-2015, 11:02 AM | #20 |
Finished Shoulder Belt pictures
03-02-2015, 09:33 PM | #21 |
is this what stock belts looked like in a 71, mainly the buckle. I need to get some soon. I need bolts and belts, I have nothing. I would like to get the right look when I do buy. a pic of factory stock belts in a 71 would n be nice
03-02-2015, 02:47 AM | #22 |
good info! was wondering why the seatbelt bolt from my 69 didnt fit in my 67
