02-10-2015, 01:46 PM | #1 |
found a doner... what parts?
I have found a 6.0 4l80 combo in a 2001 2wd 2500.
Other than the obvious items, what else should I have pulled. I wanted the entire truck but that is not possible due to the seller. Motor Manifolds Ecu Ft drive accessories Harness ??? Thx!
1967 C10 SWB Owner - Rustbelt Restorations Last edited by DaHos; 02-10-2015 at 01:51 PM. Reason: .. |
02-10-2015, 02:58 PM | #2 |
meowMEOWmeowMEOW
Re: found a doner... what parts?
The transmission usually helps
Otherwise its accessory stuff thats optional. Some folks might take stuff like power steering hoses, A/c lines, fuse boxes, engine covers etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
02-10-2015, 09:26 PM | #3 | |
I'd try to use use everything I could so I don't have to take my wallet out for all the little parts. Depends if the vendor will let you grab it all or if you have to pay for everything.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
02-11-2015, 02:04 AM | #4 |
meowMEOWmeowMEOW
OE tanks are HUGE and cumbersome IMO. I've never used the OE pumps either, as I've needed more fuel pretty much immediately. The stock pumps can't handle 400hp reliably imo.
The truck regulator is on the fuel rail, so it'll come with the engine already. Take transmission lines!
