02-10-2015, 02:50 PM | #1 |
Transmission cooler lines?
Ok i am to the point of installing the trans cooler lines and need some opinions. Metal or rubber? I have looked over the FAQ's and found nothing on this.I am running a 700r4 and i have no idea on size of hose or fittings. If i did go with the rubber hose what fitting could i use to connect to transmission. Right now I have nothing so any help, do's and dont's would be great. Oh i am running an external cooler.
02-11-2015, 01:24 PM | #2 |
Re: Transmission cooler lines?
I am running the same 700R4 trans. Here are the parts I used when I installed it:
- Hayden trans cooler- plate- 679 - (2) 48” hard brake lines 5/16” - the hard line adapters are 5/16" 1/4"NPT and look like this I always limit my rubber hose usage because it deteriorate over time, whether it be trans or fuel lines. I did run the rubber hose right where it connects to the trans cooler. Just slip it over the hard line and hose clamp it tight. Boucher'
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
