08-24-2003, 07:53 PM | #1 |
Carrier
Well today I dug into my rearend. It was to be a simple task of pulling out the axles to replace some wheels studs I broke off. Soon it turned bad. The lock screw had broken off in the carrier. I tried using some easy outs to get it out, but could get a good angle on it. I ended up breaking a drill bit off in the screw! I then drilled into the carrier, through the lock screw, and was able to get the pinion shaft out, along with the axles.
My problem now is that I have to get a new carrier. No one sells just the plain non-posi carrier, so I guess I'm going to have to upgrade to a posi unit. I'm not totaly bummed about this, as I was planning to do this eventually, but now I have to and really wasn't planning on doing it (didn't have the money set aside for this project). I figure also, rather than spending the money for an open diff, spend a little more and get what I want. I think while I'm in there I'll change gears to 3.42 from the stock 3.08. What's people's opinions on the auburn differentials? What about gears? I've had a few friends break richmond gears soon after installing and they were professionally installed and properly broken in. (Also on 10.5" slicks, but who's keeping score?) |
08-24-2003, 08:04 PM | #2 |
PROJECT 7DEUCE
Yukon gear make's a good gear set . That's what I run in my rock-crawler and they are still great. Never heard anything bad abiut the auburn ,but I have a spool in the rear and a limited slip in the front.. BTW you should not run a spool in the rear as it tend's to wear out tire's, but sure is fun to drive in the rain..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-24-2003, 08:13 PM | #3 |
Formerly yellow72custom
Eaton Posi units are rebuildable, but Auburn Posi unis aren't. The Auburn posi is a stronger unit and will proably provide slightly better traction, but it will need to be replaced when it goes out (and all posi units go out eventually), while the Eaton can be rebuilt.
You could go pull a carrier out of a junkyard truck for next to nothing, but i agree, as long as you have the rear apart, upgrade it to positraction and the gear ratio you want.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
