![]() Join Date: Jul 2014
Engine oil cooler
How many of guys are still running the engine oil coolers or have you removed them?
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
Boosted Member
Re: Engine oil cooler
I'm running an engine oil cooler....however I'm also turbocharged, and the turbo puts a lot of heat into the oil.
Regardless, an engine oil cooler is never a bad idea. A cool engine is a happy engine.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Not running an oil cooler on my install. You don't want to run an oil cooler unless it's built into the radiator or on a thermostat; running engine oil through a cooler that's "on full time" can keep the oil too cold.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Old member
No coolier for me either. Don't think it's necassary if not turbo'ed are not pulling trailer with it which I'm not doing either with mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
meowMEOWmeowMEOW
Not running one either. Heat in the oil radiates into the rest of the engine, so the regular cooling system will handle its heat load normally. Oil coolers usually are more useful in FI apps where your artificially generating more heat that would be there, or in an industrial engine that runs in place all day and doesn't have an air-cooling system. (for reference, they'll use fluid pumps through resevoirs and oil coolers as needed)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Old member
Just some info for you to.
If you are considering using a more-efficient cooler for your automatic or installing an engine oil cooler, first consider installing an oil-temperature gauge. If your oil temp never exceeds 200 degrees Fahrenheit, a cooler probably isn’t necessary. But if you find that your ATF consistently spikes higher than 210 degrees Fahrenheit, the heat’s on to install a better cooler. ![]()
Thanks guys. The original V6 had the optional oil cooler and one of the lines failed on me, just thought if it wasn't need I'd get rid of it on the new motor too.
