Old 02-12-2015, 02:32 PM   #1
Captmatt
Radiator support mount problem
I'm replacing the cab mounts and radiator support mounts. All the nuts and bolts came off with no problems. When I try to lift the radiator support I cannot get any separation from the frame. I have placed the jack in several different locations with the same result. Am I missing a mount location? I have 4 cab mounts and 2 rad support mounts. Is there a specific spot to try and lift from?
The truck is a 64 c10, thanks in advance.
Captmatt is offline   Reply With Quote
Old 02-12-2015, 03:17 PM   #2
Andice
Andice's Avatar
Re: Radiator support mount problem
You may need to loosen the upper and lower inner fender bolts on drivers and passenger side. Just enought to allow you to slide new pieces in place.
Andice is offline   Reply With Quote
Old 02-12-2015, 04:15 PM   #3
Captmatt
Sounds like a good idea, thanks !
Old 02-12-2015, 03:19 PM   #4
padresag
you may have to drive that bolt up. try separating the washer and rubber from the bottom of the support first . it has all compressed into one blob and it is like the bolt is frozen in there
ron
padresag is offline   Reply With Quote
Old 02-12-2015, 04:20 PM   #5
Captmatt
ron
Another good idea, I have hit the bolt with a hammer ( lightly ) and put the jack under the bold and carefully lifted. Still won't budge. I'm going try your suggestion now.....back to the garage. Thanks
Old 02-12-2015, 04:55 PM   #6
Captmatt
ron
That was it ! Thanks ! Hard to believe that those 2 metal and 1 rubber washers would be so frozen together that they would hold the weight of the truck.
Thanks again
Old 02-12-2015, 06:50 PM   #7
padresag
Thanks again
your welcome. I was down in your area last spring picking up a pup on Hutchinson road.
ron
