02-13-2015, 12:37 AM | #1 |
Active Member
72 Re-decal the Door panel insert woodgrain
I had the common scuff and scrapes on the woodgrain on both door panels, $21.95 and a half hour on each panel it turned out fairly nice. The small outlined raised edge I left covered and I might cut and expose later...
02-13-2015, 12:47 AM | #2 |
Re: 72 Re-decal the Door panel insert woodgrain
looks good, what materials did you use
is that a vinyl wrap?
"They Don't write songs about Hondas " 1972 C10 "Ole Red--blood, sweet & beers" USMC 1989-1997 1st Anglico |
02-13-2015, 01:39 AM | #3 |
Active Member
Yes, Vinyl Adhesive backed from Metro Restyling on there ebay store.
It is Cheyenne Teak WOODGRAIN VINYL Sheet Adhesive Backed and the size is 30" x 36" and you can do 3 door inserts. I had to get a larger sheet due to which way the grain runs. They have many, many wood grains but this was my choice. It's alittle lighter than the original but looks very nice.. |
02-13-2015, 03:21 AM | #4 |
Looks really good!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
02-13-2015, 10:24 AM | #5 |
Looks great. A person with really steady hands (like a pinstriper/sign painter) could paint that raised rib silver.
02-13-2015, 10:27 AM | #6 |
Florida Edition
Looks good to me also.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
02-13-2015, 12:17 PM | #7 | |
Active Member
And thanks for the kind words...
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. Last edited by SWB; 02-13-2015 at 12:41 PM. |
02-15-2015, 01:16 AM | #8 |
02-13-2015, 10:41 AM | #9 |
Them look awesome. I have a question/request for you though. Is there any way that you could provide some info and possibly pictures of how the inserts are attached to the door panel. I am planning on adding a set to my door panels which were not originally equipped with them. My panels have the chrome trim ring in the same shape as the inserts, but no inserts. Any pictures and tips/info would help me out.
02-13-2015, 11:09 AM | #10 | |
Active Member
The inserts are basically held on by nail style pins that go through the main panel and bent over. The pins go through elongated holes and acouple smaller round holes for a true alignment
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
02-14-2015, 04:02 PM | #11 | |
Active Member
02-14-2015, 05:47 PM | #12 |
02-13-2015, 11:38 AM | #13 |
All about them K’s
Could you post a link to where you got the vinyl?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
02-13-2015, 12:40 PM | #14 |
Active Member
Here is there web page and the grain/color I used,
http://www.metrorestyling.com/Flexib...chteakwood.htm Here is there ebay store where I purchased mine, but this auction is not the size I got..I think mine was 33" x 34" make sure you ask which direction the grain runs, then do the math http://www.ebay.com/itm/Cheyenne-Tea...52653e&vxp=mtr
02-13-2015, 06:46 PM | #15 | |
All about them K’s
02-13-2015, 12:50 PM | #16 |
What direction is yours running? Maybe it's a dumb questions, but I'm not sure im following you.
02-13-2015, 01:25 PM | #17 | |
Active Member
Also I used a hairdryer to help stretch the outside corners, and it also helped the inside corner too. But be careful and don't melt it, wisk it on and off the product and not directly and steady on it.
02-13-2015, 06:00 PM | #18 |
That looks really good!
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
02-14-2015, 04:04 PM | #19 |
Dang that looks real good!!! Awesome job!
02-14-2015, 04:22 PM | #20 |
Nice job!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
02-14-2015, 04:50 PM | #21 |
Kung Fu Master
Wonder which style would match the closest to original?
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
02-14-2015, 06:28 PM | #22 |
SWB 4x4 Collector
Original 70s era 3M di-noc.
The metro restyling vinyl is good quality but is really orange toned in person. You did a good job though on them. 3M 94 primer helps stick on anything rounded off. A sharp hand with a fresh exacto would get your silver edges back. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-15-2015, 03:53 AM | #23 |
Moderator
That looks really really nice
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-15-2015, 04:30 AM | #24 |
Cluster King
I agree, great work and interested.
Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
02-15-2015, 08:55 PM | #25 |
Active Member
Thanks for the kind words...
