Track bar frame mount
Anyone have a custom track bar frame mount or used something other than the factory bracket. I need to drop my track bar down a few inches on the frame side in order to reduce the angle on my track bar.
Re: Track bar frame mount
![]() Join Date: Oct 2012
Thanks again SCOTI. That is definitely doable. and to think I was gonna buy one (PHB).
If you're a DIY'er, this info can build the whole enchilada (for up to 8" rear c-notch style drops)....
http://67-72chevytrucks.com/vboard/s...d.php?t=523723 http://67-72chevytrucks.com/vboard/s...d.php?t=450565 Beyond that, the truck arm mount wouldn't work integrated into the lowering block & be level @ ride height. Most likely, it would need to be part of the T/A.
Thanks Scoti. Probably more than my fab skills are capable of. I'll probably sell the track bar I have now and invest in a PB bar when I do a C-notch.
Here's a few shots of mine. Pretty simple. I used a piece of diagonally sliced tubing to make the angle. It's a CPP track bar, now double adjustable, with a CPP bracket on the truck arm.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
I am coming back to this now that I have redone part of my suspension. I am considering taking the rivets out of the current mount, installing some sort of spacer and remounting it to the frame with grade 8 bolts. Has anyone done this? My only concern is the force which would be applied to the bolts, especially considering the force will be applied 2-3" from the frame. I am thinking I could use a piece of rectangular tubing as the spacer.
