Door Bumpers
I see this door bumper listed for a '63. My truck does not have these bumpers. Should it have these bumpers, where do they go and how many per door? Can someone post a photo showing location?
Thanks for the help, Hugh |
Re: Door Bumpers
Here is where they go on a '64 GMC
Re: Door Bumpers
Thanks for the quick reply. I guess the previous owner filled the holes. I should be able to get them close enough from your photo.
Hugh |
1961 crewcab
Re: Door Bumpers
on my 60, and 61 they are up here:
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: Door Bumpers
My buddy's' 63 has no holes either.
![]() Join Date: Nov 2007
Re: Door Bumpers
Nor does mine.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
Re: Door Bumpers
mine had the holes, but they were too small for the reproductions. It's no big deal, just drill some new ones and push them in.
Re: Door Bumpers
The repros come in two sizes: one for big holes and one for small. My truck (a '64) uses the ones for the smaller holes.
Re: Door Bumpers
yup... at least from LMC the ones for 60-63 are the small ones and the ones for 64-66 are the big ones. Too bad my 65 had the small holes. But it was nothing a Step ream couldn't fix.
Re: Door Bumpers
my 61 had no holes and weren't filled either. anybody really know about these?
1961 chevy K10 my build is------------61K10 build |
![]() Join Date: Apr 2012
Re: Door Bumpers
x2 on LMC having the right ones, I think this is the ONLY thing they got right.
Re: Door Bumpers
my 63 do not have holes too and i don't feel that they have been filled. i very closely look and cannot see a welded/grind area.
Re: Door Bumpers
I thought I had missing door bumpers but sounds like maybe not. I am in the middle of the Honda weatherstrip install and will wait until I finish and see how the doors close. My truck was made in Baltimore. I wonder if assembly plant determined if the truck had door bumpers?
Thanks for all the replies, Hugh |
#14 | |
![]() Quote:
![]() Thanks, Sam |
#15 | |
Re: Door Bumpers
#16 |
Chevy addict
Re: Door Bumpers
The "V" shaped guide in the door jamb below the latch takes care of the no bumper situation
#17 |
1961 crewcab
Re: Door Bumpers
I took a look at a few of my trucks, looks like all the 63's did not have them, I have 3 chevs, and a gmc...
I have 1 60 with them, and 1 61 with them, and 2 61's without....(all chevys), and 1 61 gmc with... I have a 66 gmc with none in the lower spot, and a 66 chev with them in the lower spot...
#18 |
Re: Door Bumpers
What's the easiest way to install the bumpers? I was thinking a mild soap and water solution or rubbing alcohol like when installing handlebar grips.
#19 |
Chevy addict
Re: Door Bumpers
Spray glass cleaner around the hole and on the rubber and twist it in
#20 |
Re: Door Bumpers
Back in the day when putting tight handlebar grips on my old Indians after a rebuild, I read somewhere to use hairspray, I tried it and it worked great. It was the old aerosol type. I am sure this would work with this application as well.
