Old 02-14-2015, 11:03 PM   #1
H20cooled
Performance shift mode wire?
Hello! I have not had a chance to call BP Automotive and ask what this wire is for but I thought maybe someone on here could answer.
I have a wire off of the BP Automotive Harness that is labels performance shift I have not idea what it is for or how to use it. I tried searching everywhere but I have not found the answer. Any ideas? I still have the other ones like TCC so its not that.
Thanks,
Rich
H20cooled is offline   Reply With Quote
Old 02-14-2015, 11:42 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Performance shift mode wire?
My guess is its the the tow/haul wire that some folks use to switch to a different set of tq management and shift settings. Your tuner needs to actually set those parameters.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-14-2015, 11:47 PM   #3
H20cooled
What would I do with the wire then?
Old 02-15-2015, 01:31 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Look up "tow/haul performance mode"
You'll get a list of threads from Ls1tech, HPTuners forums, and a few other places. They Explain how it works in more detail. Usually it would wire to the tow/haul button on the stalk, iirc, you just hook it to a switch. With the settings in the ecm, when the switch is on, it will change modes.
They have more specific info on how to wire the switch.
Old 02-15-2015, 01:46 PM   #5
H20cooled
Thank you! Going to try to wire in a lighted momentary switch to use for this.
Old 02-15-2015, 02:12 PM   #6
ls1nova71
ls1nova71's Avatar
If it is in fact a "tow/haul" wire, it would need a momentary switch to ground. As Brew said, it needs to be enabled in the tune to function without the BCM. As for an indicator light to know when it's on, I have never been able to figure out how to do it. I rarely use mine, as it just delays the shifts, and I usually dont think about it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-15-2015, 05:36 PM   #7
H20cooled
Why not use something like this- Momentary Switch?
Old 02-15-2015, 06:30 PM   #8
ls1nova71
ls1nova71's Avatar
That is an illuminated switch, but I don't think it comes on when the button is pushed once and goes off when pushed again. It also says it is a 'resettable' switch which I thought meant it was a latching type switch (which you can get that go on and off when the button is pushed, but won't work because you have to have only a momentary ground). Kind of confusing add since it also says it is a momentary switch?
Old 02-15-2015, 06:56 PM   #9
H20cooled
I hope its a momentary switch since that is what it says but it is confusing. I think I will message them and find out.
Rich
Old 02-15-2015, 08:39 PM   #10
H20cooled
I emailed them and was told "It's on and off switch" so its not what the descriptions say, I hate sellers like this that use wording to trick you into believe it is one this and its not. I just bought a not lighted one that should work good and is a real momentary switch.
Old 02-15-2015, 08:44 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
AllElectronics.com or Mouser.com will have about 500 options for you. As a warning, cheap led-lit toggles and momentaries can leak on the light circuit and cause false continuity. I usually avoid lit switches, and instead wire in an indicator LED
Old 02-15-2015, 11:41 PM   #12
aknovaman
This only works on early operating systems. Not all p59 ls1 style pcm's.
http://www.hptuners.com/forum/showth...-Switch-Option
Tow haul is the same as performance mode switch. It is enabled with a momentary switch like a door bell button. One press enables it; a second press disables it. Every time you shut off the car, it goes back to normal mode. The trans pressures and shift points are changed as it uses differnt settings in the trans tables.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 02-17-2015, 09:40 AM   #13
Hart_Rod
Hart_Rod's Avatar
Good info!
Hart_Rod is offline   Reply With Quote
