Another lwb to swb
I'm planning to begin the shortening process of my newly aquired 71 c10 tomorrow. I have been reading up on this and have a question. I am going to attempt to cut down the bed instead of buying new bedsides but am seeing 2 different dimensions being used. I know that I need to remove 12" out from in front of the rear fender wells since I will be removing 12" from the frame under the cab but how much off from behind the rear fender well. I have seen some say 6" and others say 8". What is the correct amount to make the bedsides match that of the swb?
Thanks for the help. |
Re: Another lwb to swb
8" out of the rear.
Thanks for the reply. I actually just found another thread about this a couple pages back. I'll post up some pics as I go.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Here you go, in detail... http://67-72chevytrucks.com/vboard/s...ow+buck&page=8
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Good question..........1/2 inch is going to be a real pain in the a-- to remove..maybe call a company that makes it and ask them?
looking forward to see your short bed though
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
It will look good with the 12 and 8 combo. I did mine like that.
It will look much better.
Looking good so far...8" inches! 8" + 12" = 20"...20" inches is the magic number...Use a stiff wire wheel on your grinder to remove the bed liner material...Pay close attention to Kevins details in that link I posted...Take your time with the fit up and use tack welds instead of beads when you get the fit right. I would also suggest getting some of these... http://www.harborfreight.com/welding...mps-60545.html Be sure and wear a shield over your face and a thick shirt and jacket when using the wire wheel! keep the pics coming...
Nice work boys. Is there a magic spot to cut so the bed mounts line up ? and waiting to see where ya cut the frame. I assume under the cab would be best?
#11 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 02-19-2015 at 01:49 PM. |
I agree the short bed will be sweet once done. I am now contemplating on disassembling the bed and "fixing" the bedsides on the table rather than on the truck since the beadliner is being a bi%&$. Then I will be easier to remove the bedliner. Since I plan to bag the truck I am going to go ahead and plan for the future and install the notch and raise the bed floor now instead of doing it later.
I will cut the bed under the cab so that I do not have to move that massive crossmember. Also the "Z" cut is the best. |
Well finally made some progress. Got the outer seams tacked together. Also found that if I cut the bed liner into strips I can peel it out but will still be very labor intensive.
Is there any downside to welding up those seams with stainless mig wire? I tacked them with .035 wire but have a smaller diameter roll of stainless that I can use to finish stitching back together but if I need to I can buy a smaller diameter regular wire if the stainless will not work. ![]() ![]() |
As far as the bed liner, are you planning on taking to entire liner out, or just the area to be welded ?
We completely removed a green colored liner out of my sons 02 silverado that was at least a 1/2" thick (looked like two liners on top of each other done in someone garage ![]()
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
#15 |
Get yourself some .023 er70s mig wire. I wouldn't risk the possible issues resulting from the unknown influences of the stainless filler.
I have found with the little stainless welding I have done that it needs stainless filler and vice versa.
#16 |
![]() Join Date: Jan 2002
Just thinking out loud but could you sandblast the bedliner out?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#17 |
Wow! You weren't kidding about it being almost 1/2" thick. That's insane.
I did the SWB conversion and ran into the same bed liner issue with welding. Mine was nowhere near as thick as yours. I did about 2 - 3 rounds of aircraft stripper, then was able to hit it with a grinding disc to weld. My guess is that you'd have to make like 8-10 rounds of stripper to get that off. I had my inner fenders dustless blasted and it took off all the junk, undercoat, etc. The fender where easy because I just threw them in my truck bed and drove there. |
#18 |
I read some where that dry ice was used to remove stuff like fat mat, dyna mat. Once froze it just chipped off. That's going to be a lot of ice though but worth trying in a little area.
#19 |
#20 |
US Army Veteran
![]() Join Date: Nov 2008
How's progress coming? Watching this intensely, as I'm considering doing the same myself this spring.
Any "gotchas" or "man, I should have done it this way" you can share, will be most helpful!
1972 C10 Highlander - The making of a daily driver |
#21 |
I just want to know what was faster. cutting the bed in two sections and welding it back together, or getting the bed liner out?
#22 |
Cutting the bed was fast since the bed is back in one piece and the bedliner is still not completely out.
#23 |
quick question. once I stared removing paint and welding back together there was a lot of bondo in the areas around the welds. I am thinking of separating the outer bed panel from the inner bed panel so I can hammer and dolly everything the cut down on the bondo as they had ALOT on there but I cannot get to the backsides as the clearance to the inner panel is too close. Does anyone know where all he spot welds are?
#24 |
Well I got my exhaust shortened and replaced my mufflers. Dropped off the driveshaft to be shortened. Replaced all the cab mounts and core support mounts. Now I have to adjust my doors as they will not close. Is this normal after replacing some badly worn cab mounts?
#25 |
