Old 02-17-2015, 09:50 PM   #1
Nwiggins
Front brake drum removal
I need to replace the front drums on my 67 C10.
Spindle and drum are bradded together.
New drums come without spindle.
I assume I need to just drill the brads out and use the same spindle.
Anyone know if that is the case?
Nwiggins is offline   Reply With Quote
Old 02-17-2015, 09:59 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Front brake drum removal
That would be correct. Drill them or grind the heads off and punch them out.
Oh, and welcome to the board....
LockDoc
Leon
Old 02-17-2015, 10:13 PM   #3
Nwiggins
Hey thanks.
Trying to get it road worthy again so my son can take it to the prom like I did 27 years ago.
Harmonic balancer got loose too. Thought I'd drill and tap the crank shaft, put new key stock in place with JB weld and secure with a bolt and washer. Any thoughts on that.? It's a 250 6
Old 02-17-2015, 10:29 PM   #4
LockDoc
LockDoc's Avatar
Hey thanks.
If the outside ring on the balancer isn't loose I guess it would work. If the rubber ring between the inside and outside metal parts is bad you will have to replace the whole thing.
LockDoc
Leon
Old 02-17-2015, 10:50 PM   #5
Nwiggins
Rubber is good. It's a new balancer.
Old 02-17-2015, 10:56 PM   #6
LockDoc
LockDoc's Avatar
If it's new and it is loose it must be the wrong one. It should be a very tight fit. I don't think the JB Weld will do any good.
LockDoc
Leon
Old 02-18-2015, 09:46 AM   #7
GRX
GRX's Avatar
Yeah, balancer is a press fit. If loose it must be the wrong one.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
