Throttle linkeage from firewall to carb
Does anyone know when you can get a replacement rod from the pivot at firewall to the carb? I am running an Endelbrock 1406 on high rise performer manifold. The rod was bent to accommodate an older two barrel setup from previous owner. Straightened it up a bit but am looking for ideas to get one that has not been bent.
#2 | |
The Older Generation
Re: Throttle linkeage from firewall to carb
I don't know if they are reproduced or not. You might check on the parts for sale board on here and see if anyone has one for sale. You can't post a wanted to buy unless you are a Premium member but if you see one for sale you can buy it. LockDoc
I have the same problem but I think I am going to just change the accelerator to the cable type from a 71 truck. Might work for you also.
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
New to site, explain Premium member ?
A guest is someone who drops in and reads but cannot post.
A registered member has a name (in pink) and can post. But a paid subscriber (name in blue) opens up privilages like posting classifeds like "for sale", wants or valuation of items. http://67-72chevytrucks.com/vboard/payments.php
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Go up to toward the top of this page and you will see a blue menu bar, click on the word "Subscribe" and it will list all of the different types of memberships. A Premium members board name is in Blue instead of Pink. LockDoc
![]() Join Date: Sep 2007
i think brother had em. if not i should have an extra in my stash,
1967custom |
and the yearly dues are well worth it in knowledge alone!!
1967custom |
![]() Join Date: Dec 2012
take it off.....
tap it straight with a rubber mallet on a piece of 2x4 and get it all cleaned up and happy. Then build a nice throttle linkage bar for it from 2 Hein joints and a piece of polished aluminum rod from Ace Hardware. You'll be done in no time for under $10 Have a functional smooth feeling throttle.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
