Old 02-20-2015, 09:29 AM   #1
C10agent
C10agent's Avatar
Porterbuilt C Notch Question
I am about to order parts for my back half. I already have ECE adj track bar and shock relocate brackets and was needing to know if these parts are compatible. Can I order just the C Notch or do I need to get the entire Stage 2? Thanks,
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 02-20-2015, 10:07 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt C Notch Question
The C-notch can be run as a stand alone piece, however there is a little tab off the top section that our upper shock bar bolts to. Since you are running the ECE shock relocators and factory upper shock crossmember you will need to cut that tab off, as it will interfere with the factory upper shock crossmember.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-20-2015, 10:27 AM   #3
C10agent
C10agent's Avatar
Nate
Nate, you are the man! Thanks for the quick reply and I will be ordering soon.
Neil...............
TEXAS Y'ALL!!
