Custom Autosound Speaker Installation... Little help?
I am installing a custom autosound dual speaker in my 78 C10. Anyone know if the speaker gets installed from the top or the bottom. Top fits snug and holes line up perfectly. However, the speaker is raised a tad. If I install from below, it's flush with dash, holes line up, but there will be a little gap between the screw hole (speaker) and dash hole.
Re: Custom Autosound Speaker Installation... Little help?
Clarification.... I am talking about the single speaker in the middle of the dash. I bought a replacement from LMC, the Custom Autosound Dual. I took the dash off, cleaned up 35 years of gunk, and am now ready to install the speaker.
Here's the Question.... Does anyone know if the speaker drops in from above the dash or if you have to install from below the dash? Above = feels like natural fit but speaker protrudes a tad. From under, speaker does not protrude but the mounting bracket is not flush with the under dash |
I came here to get an answer to this too. Anybody have any help they can offer?
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
chevy truck fan
you might try looking/searching in the elctrical "truck audio" section too. it doesn't get as many views, but I bet you might find your answer if you do a "forum search"....good luck
Crap. I just did this and I can't remember, 100%. I think it was from the bottom and I had to look it up when I did it, so pretty sure it's correct.
![]() Join Date: Jun 2015
I replaced my center dash speaker last summer when I replaced the dash pad in my 1979 K25. I'm pretty sure the speaker sat on the dash and I screwed it in.
Follow this thread to the bottom. https://67-72chevytrucks.com/vboard/...d.php?t=829234
May not apply to your particular speaker. |
Just here to tinker
![]() Join Date: Jun 2008
Every unit I’ve seen sits on top
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
![]() Join Date: Oct 2014
From the bottom, that’s how I did mine.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
![]() Join Date: Aug 2017
From the bottom is how I did mine as well.
Yup I did mine from the bottom. If you haven't bought parts yet you can buy a plastic adapter to fit two 3.5 speakers in there to get more a stereo sound. That's what I did and the adapter was mounted from the bottom
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
My original sat on top and I mounted the replacement on top as well.
Bob Q. '83 K2500 6.2L |
When it the same a style sizing as factory there on top, when styling is thicker and bigger you may need to mount under or a drop bracket( made up custom made). So when it come to the set up what make to best fit for finish that you like or make the cab as factory looking as you can flow that style. So it comes down to what you want uses, and how you use part get the look you want done.
Some time adding foam cut out rings to any speaker will boot the sound throw the panel/open facing it to.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 01-21-2022 at 03:08 AM. |
