08-25-2003, 08:43 PM | #1 |
Is this good enough?
Is this good enough for light welding duties ? Like bumpers,rocker panels,ETC. ???
Soon to have 68 SWB 350 with Turbo350 |
08-25-2003, 09:03 PM | #2 |
Campbell hausfeld Flux Core 85 Amp Electric Wire Feed Welder
Model: WF2010 Wire feed welder provides an instant arc for easy welding 115-Volt Input plug in anywhere and saves you cost of wiring for 230 volt 30-80 Amp Output welds 20g – 3/16” steel, and is easy to match heat to metal DC output provides a smooth weld bead for increased satisfaction and results Duhh
08-25-2003, 09:56 PM | #3 |
t
08-25-2003, 10:07 PM | #4 |
Flux-core welders are ok if you don't mind doing alot of grinding. Mig welders are the only way to go when it comes to body work. I use a Lincoln SP-125. It's a standard 115 volt also.
08-25-2003, 10:13 PM | #5 |
migs do it clean /????
08-26-2003, 12:14 AM | #6 |
PROJECT 7DEUCE
Flux sux!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-26-2003, 12:29 AM | #7 |
Fabricate till you "puke"
You can weld sheet metal with a flux core welder......but it takes some patience! I have welded the sheet with an AC stick welder(that took a little practice!) Also like Randy said, you will do a lot more grinding. I run an sp100 Lincoln for the tin, but on the heavy stuff, it doesnt have enough "juice". i still use the old Lincoln stick welder for any bumper or chassis brackets. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-26-2003, 08:40 AM | #8 |
Mike
It's not much more for a mig welder.Local welding supply shops have small bottles of gas that are reasonable.The gas will last quite awhile doing sheet metal.Just remember to turn it off.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
08-26-2003, 11:36 AM | #9 | |
08-26-2003, 02:50 PM | #10 |
Flux Sucks !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-26-2003, 03:25 PM | #11 | |
08-26-2003, 03:29 PM | #12 |
Get a MIG
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
