02-23-2015, 05:16 PM | #1 |
New truck incoming
After a great deal of searching I've snagged a new truck.
1976 SWB 4x4. Truck is Arizona raised, rust free. the 350 was rebuilt by a local machine shop and a 700r4 was rebuilt and installed as well. Running 4.10 gears on the rear and the NP205 T-case. It's a camper special with an extra leaf on the rear. The bit I don't like is a sunroof was installed. But I've been told it's leak-free, I'll learn to love it or I'll deal with it down the road. Dash pad is in poor shape and no radio is installed right now, but dash isn't cut. Now for pics...
1987 R10 1976 K10 |
02-23-2015, 06:54 PM | #2 |
What Hump?
Re: New truck incoming
Yep that's an AZ truck alright, can tell from the dash. Nice find!!!
Keep checking the sunroof though, they don't leak because it hardly rains here.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
02-23-2015, 08:43 PM | #3 |
Nice looking truck! I really like the front-end. It's what mine would look like if all spruced up.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
02-23-2015, 10:19 PM | #4 |
Beautiful truck.
1973 K10 Super 8 http://67-72chevytrucks.com/vboard/s...d.php?t=645525 Sold 1988 S10 http://www.s10forum.com/forum/f135/p...-papaw-470214/ 2010 Nissan Frontier 4wd DD 2008 Ford Escape Limited Awd Momma's Ride 1978 C20 Farm truck Sold |
02-24-2015, 09:11 AM | #5 |
Thanks!
The steering wheel and dash pad will be replaced first, baring any mechanical issues. Some confusion on which dash pad will work... 73-78 was the same, then 79-80 was different? (Obviously 81-87 is different). Cheers Taylor
1987 R10 1976 K10 |
02-24-2015, 03:40 PM | #6 | ||
Nice truck!! Looks like your time spent searching for a good rust free one paid off!
The 79-80 pads have a rectangular opening in the dash for the VIN plate to show through. Otherwise, they look the same as a 73-78 pad. LOL! ... and here I was thinking that doesn't look all that bad for an AZ dash. It looks way better than the one in my 77 plow truck ... I'm not sure what made this one crack so bad. Quote:
However, it has the wiper switch on the dash too so there's still a good possibility that it's the original cab. Someone probably just swapped in the newer column to add tilt. And swapped on newer doors to add power windows & locks. |
02-24-2015, 09:42 AM | #7 |
Robert Olson Transport
beautiful truck the other thing I noticed is that is not a 76 column that's an 84 up column better make sure they didn't ddo a cab swap and leave another VIN in there
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-24-2015, 01:57 PM | #8 |
Good eye!
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
02-24-2015, 02:06 PM | #9 |
Where is the VIN stamped on a 76? Same as my 87?
1987 R10 1976 K10 |
02-24-2015, 11:11 AM | #10 |
Truck looks great ! I've didn't think "Camper Special" was available on a shortbed !?
One tip for your sunroof. On a full sunshine day - open ,or remove, the sunroof and clean the seal with glass cleaner , or anything, then coat the seal with petroleum jelly and let it sit with sun on it for at least an hour. Alot will soak-in and you can wipe off any excess. It will make the seal feel like new - soft and pliable , and seals better.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
02-24-2015, 12:18 PM | #11 |
That rubber seal trick sounds similar to something I've done to soften old carb boots on motorcycles... Use a mixture of wintergreen oil and xylene to soften them. Works great.
1987 R10 1976 K10 |
02-24-2015, 01:09 PM | #12 |
That is one nice truck
02-24-2015, 01:12 PM | #13 |
Fine looking truck!
02-24-2015, 04:09 PM | #14 |
Sweet truck! Whats your plans on her?
02-24-2015, 04:34 PM | #15 |
Good eyes on ya'll!
The PO wanted something he could get up to interstate speed with, so he ditched the 3 speed for a 700r4 (kept the 4.10 rear). He added power windows and locks, and tilt wheel. He's been using the truck as a camping vehicle and wanted a little more comfort. My plans are to take it back a little closer to stock, at least appearance wise. It's to be my daily driver. Stock wheel, new dash pad, stock radio. I'm going to install a modern stereo behind the seat or in the glove box... I want it hidden, but I want the modern functions. I'm also going to lose the 4.10 gears. They're more than I need. I'll be searching for 3.42 maybe, haven't done my research yet. She'll get a spray-in bedliner, the carpet will come up and sound deadening will go in, then carpet back down. I'll keep her civilized. Cheers
1987 R10 1976 K10 |
02-24-2015, 10:02 PM | #16 |
Nice truck! First thing I noticed was the 79-80 hood.
02-24-2015, 11:29 PM | #17 |
the trans swap explains the newer column The VIN is supposed to be riveted to the pillar but I was gonna say pop off the dash cover and make sure there is nothing in the way of a VIN on the dash left
02-24-2015, 11:42 PM | #18 |
The vin on the pillar is present and matches the title.
I'll be removing that dash before long regardless! I believe the guage cluster is original, therefore won't indicate a setting for overdrive.
1987 R10 1976 K10 |
