02-24-2015, 02:25 PM | #1 |
1987 GMC R3500 dually with th400
I have 1987 GMC R3500 dually with th400 I was wondering what upgrade I can do with th400 for hauling towing
02-24-2015, 04:06 PM | #2 |
Re: 1987 GMC R3500 dually with th400
I used a B&M Traveler torque converter designed for towing and a 34 element sprag and a deeper pan with cooling tubes for mine along with a complete overhaul. I know there is more you can do but this is what my budget allowed. Look at mikestransmission.com and other simular sites to get more ideas. My 1987 Cab and Chassis already had the heavy duty transmission case. I ended up parking the truck after about 20,000 miles due to engine problems and not needing a heavy hauler anymore.
02-24-2015, 04:42 PM | #3 |
new fluid, and a good tranny cooler. th400 are pretty tough.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
02-24-2015, 05:06 PM | #4 |
x2 tranny cooler. These transmissions are pretty tough as is. Just keep it from getting too hot and it'll be happy.
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
02-24-2015, 06:11 PM | #5 |
Beyond a fluid change + fresh filter, a trans cooler & shift kit are good investments.
02-26-2015, 03:36 PM | #6 |
If you are going to keep the truck and want better mileage update it to a 4L80E transmission with overdrive and a lock up torque converter. If you spend any money on the TH400 other than a shift kit and filter change you would be much better off spending the money on the 4L80E swap. Transmission cooler and cooling pan are good ideas for any Heavy duty transmission.
