Old 02-26-2015, 03:53 PM   #1
firefighterchevy
firefighterchevy's Avatar
Open 3.07 to posi series questions.
Well, the internet is full of great advice...just sometimes confusing and sometimes incorrect. I hope to gain some simple answers and knowledge from you folks who know this stuff best. So, this is my plan: I have a 69 C10 that currently has an open 3.07 rear axle. I have a 3.73 posi I bought that came from a 69 C10 also.
First off, I have nothing against 3.73 gears, in fact, I have them in all my other pickups and Suburban. I just don't want them in this pickup, as I would like to keep some MPG and top end speed at lower RPM's.
As far as I can tell by reading all over, the 3.07 is a Series 3 setup. I have read various places conflicting info on the 3.73, as to it may be a Series 3 or a Series 4.
What I want to do is stay with 3.07 gears, but make it posi. Can I take the 3.73 carrier and put the 3.07 gears on it and install it in my 3.07 axle housing? Am I going to need a gear shim if I can? Will this even fit/work? I am already aware of setting up the bearings with the swap, if I can. Can some of you folks point me in the right direction? Let me know if I forgot some info that may be needed, and I did a search and couldn't find a thread like this here. Thanks.
My friends describe my house as the small town used Chevy Pickup dealership.
firefighterchevy is offline   Reply With Quote
Old 02-26-2015, 04:33 PM   #2
67 chevelle
67 chevelle's Avatar
Re: Open 3.07 to posi series questions.
To my knowledge , 3.73 gears go on a 3 series posi , so should a 3.07 , 3.73 will not work on a 4 series posi ,, I have a 4 series sitting in my garage ,, where it has been for many years because of this very issue ,,, expensive mistake
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-26-2015, 04:40 PM   #3
NYroadRat
Confirming that you can use your 3 series carrier with any 3 series gears. In short, put your 3.07 ring gear on your 3.73 posi's carrier and you're done.
NYroadRat is offline   Reply With Quote
Old 02-26-2015, 04:48 PM   #4
hugger6933
Welcome to the board first off Now the "some" 3:73 gears being 4 series gear sets is a real thing but not from the General. Those are made, if not mistaken, by gear makers to help some of the hot rodders with the issue your having but with deeper gear sets. All of the "3" gear should most def fit the posi unit for the 3 gears.
Now that that is clear as mud anything else I can clear up for you? Jim
hugger6933 is offline   Reply With Quote
Old 02-26-2015, 04:59 PM   #5
firefighterchevy
Thanks, I appreciate the input and clarification. This will make the project swap easy and reasonable since I already have everything.
Old 02-26-2015, 05:31 PM   #6
Fitz
2.72 through 3.42 use the series 3 carrier. 3.73 and up use the series 4. Your 3.07 gears will not fit a series 4 carrier.
Fitz is offline   Reply With Quote
Old 02-26-2015, 07:24 PM   #7
frankslagoon
x2
frankslagoon is offline   Reply With Quote
Old 02-26-2015, 07:31 PM   #8
cdowns
cdowns's Avatar
me i'd use that 373 posi and at the same time i'd dump the tranny and go for the extra gear and convienence of the 700-04 tranny
Old 02-26-2015, 07:49 PM   #9
Mike C
Mike C's Avatar
Yup. Those other guys are correct. In the passenger car axle you can run up to 3.90's on the 3 series carrier, but in the truck the 3.73 is the 4 series carrier. Who knows why GM didn't just use the car version of the axle in everything, but they didn't.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2015, 05:37 PM   #10
Fitz
2.73 through 3.42 gearsets fit a series 3 carrier. 3.73 and up fit a series 4 carrier. Your 3.07 gears will not work with a series 4 carrier, but don't take my word for it. Go here: http://www.drivetrainspecialists.com...ed19587-1.html
Old 02-26-2015, 05:40 PM   #11
Fitz
00
