Old 08-26-2003, 02:02 AM   #1
iluvmy72
powerglide......is it good for a truck?
I bought a tranny today for a Oldsmobile......how are these powerglides?....this one is from a 69.....can it be made into a tranny as strong as a 400 or 350 with another gear?.....or does it stay a 2 speed for life?
iluvmy72 is offline   Reply With Quote
Old 08-26-2003, 04:08 AM   #2
Phillip Johnson
Phillip Johnson's Avatar
I had a powerglide in a 65 Vette. Does that answer the question? It was a bullett proof tranny
Phillip Johnson is offline   Reply With Quote
Old 08-26-2003, 06:43 AM   #3
JimKshortstep4x4
Smile
(2) speed Powerglides are used in drag cars as they seem to work where three speeds are not needed. I have never heard of anyone adding a gear to make a three speed out of them. Personally I think a three speed works a lot better for trucks. Overdrive is a plus if the trucks are driven any distances.
Jim
Old 08-26-2003, 08:26 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Not sure but aren't the Buick, Olds and Pontiac transmissions different? Maybe different bolt pattern???
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-26-2003, 08:49 AM   #5
MJN
MJN's Avatar
I've seen a couple of our trucks in the junkyard with powerglides in them, one had a lot of options too. Both were GMC's and 2wd 1/2 tons.
Old 08-26-2003, 09:12 AM   #6
Hutch
Hutch's Avatar
iluvmy72
Mine works great for pulling the boat.
I think that the previous owner put a shift kit of some kind in it cause it downshifts at about 25 to 30 mph by itself.
I have never driven one that worked like this before.
Most of the ones I have driven would rely on the throttle to downshift.
Did they ever use them in 2wd Blazers?
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-26-2003, 10:09 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, you can easily add another gear. You have to pull it out, and install a turbo 350 in it's place. Power glides are tough trannies, but why would you want just two forward speeds?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-26-2003, 10:26 AM   #8
palallin
My old '67 had a PG from the facotry. It was indestructable. But I hated it and replaced it with a manual 3-spd.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-26-2003, 11:26 AM   #9
1970cstblazer
1970cstblazer's Avatar
The two speed Buick Olds Pontiac transmissions are called Super Turbine 300's. They are tough like the Chevy Powerglide, but nobody really wants them when they can use a TH400,TH350,TH200-4R or TH700-R4.
1970cstblazer is online now   Reply With Quote
Old 08-26-2003, 11:29 AM   #10
68LSS1
68LSS1's Avatar
I had a '56 Chevy--283 with a powerglide. That truck came out of the hole hard!!!
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 08-26-2003, 11:39 AM   #11
oldsub86
My 68 has the powerglide and it is tough. I have pulled our 23 foot Prowler travel trailer with it and it never let me down. I put a fairly decent tranny cooler up with the rad cooler first however.
I think that you might ultimately be happier with something like a 700R4 for fuel economy and cruising noise reasons but there is nothing wrong with the powerglides in terms of performance or reliability.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 08-26-2003, 12:39 PM   #12
junkyardjohn
junkyardjohn's Avatar
I'VE HAD SEVERAL POWERGLIDES (ALSO KNOWN AS A 2 SPEED SLUSH BOX) IN CARS, & THEY'RE GREAT FOR THE QUARTER MILE, BUT AFTER ABOUT 1/3 OF A MILE THEY SURE FEEL LIKE THEY NEED TO SHIFT ONE OR TWO MORE TIMES.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-26-2003, 01:32 PM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
My advice would be to sell it and get a 700r4 or th350.
I had 3 cars with the slushbox. A 63 Bel Air w/ 327 that didn't last, a 62 Nova w/ 194 that worked great and got as high as 30 mpg, and a 68 Bel Air with 283, it worked good in it. The later ones were far better than the early, and if you're going to put it in, I'd recommend a rebuild with street/strip parts.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-26-2003, 06:39 PM   #14
crazy longhorn
Fabricate till you "puke"
Those old pg's were damn near indestructable......better suited for a lite weight car tho. You can use another gear in that heavy truck I had an old frame car....eons ago! Tangled with a bud talkin trash(69 chevelle,with a warm350/350, & 4.10 gears)....got his @ss kicked! I had no speedo on the frame car, & the dude ask me "what gear were you in?" I said low the next thing I heard was bull chit, I was running 90 mph! I said , well did you hear it shift?.......that little sb was running about 7500 rpms, & pulling a tall rear gear I could run that thing up to about 40-45 mph....stuff it in nuetral , ring the snot out of it & pop it in low....it took a couple lanes to 'hang on " after that! after a couple seasons, that trans got real tired.......but never did come unglued! leave the 2spd to the guys racing.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-26-2003, 09:54 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I had a powerglide in a 66 1/2 ton and that thing got great mileage and had lot's of power. Not sure why I ever got rid of that truck .
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-27-2003, 07:41 PM   #16
Eddie H.
Eddie H.'s Avatar
I had a 70 Impala with a 350 and a powerslide. I pulled a camping trailer through the mountains all over Colorado with it.
The tranny was still going strong when the motor finally died and I got rid of the car. They're tough little trannys, just not enough gears to suite me.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-27-2003, 10:30 PM   #17
jmanz69
Careful, they attack...
jmanz69's Avatar
I had a PG in my 69 originally, but pulled to put in a TH-350. Had no problems with it, just wanted another gear in between 1st and 3rd. The 2nd gear in a PG is 1:1 just like any 3 speed in 3rd gear. So you won't gain any MPG with a 3 speed just an intermediate gear. I sold mine to a guy with a circle track car for $200. He said they work great for short track and he had 3 of them in his trailer. He also built my 327 and gave me a good price on it since he got my trans. You could maybe put a Gear Vendors O/D unit on it if they make one that bolts up. Just an idea.
jmanz69 is offline   Reply With Quote
Old 08-27-2003, 11:13 PM   #18
Lobo'74
Lobo'74's Avatar
Power Glide Impala
My first car was a '66 Impala two door. Stock 396, 325 horse with a powerglide. When I stood on it you could hear the secondaries on that quadrajet open up and watch the gas gage go down. It shifted about 55 at full throttle. No lie, I got about 8 mpg in town, 13 mpg at 70 mph on the highway, and once going across Arizona I averaged 90 mph between gas stops and got 17 or 18 mpg. However, it was a dog off the line. Got my butt beat royally by a buddy in his '64 GTO.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
