What's this ??
What & Where does it go,
I am assuming its part of the A/C or Cruise control ??? |
BAD BOW-Silverado XST
It's not part of the cruise control unless GM changed the wiring in the newer trucks. My 83 cruise should go back to the late 70's. I'm not sure on the A/C. The compressor should have a different connection unless the older compressors used a different type. Where does the wire lead from? Is it live? How many volts going through it? Looks more like a washer bottle connection.
I dont have a wire on my washer bottle, at least that I know of ?
It looks like it may have gone into the stock carburator.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
then whats the thing with the small vacuum port (large arrow is pointing at) it appears to be split from that same green wire ??
Project92 SWB stepside
The thing you are pointing to is a MAP sensor. Pull it out a chuck it!!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Oh Yeah !!
![]() I like doing that !!, I was gonna say what ever it is, I didn't need it to run the other day !! Where does the map sensor end up going to ? Cab/firewall ? >>>>>>>>>>>> Edit: ![]() I don't see any listing for a MAP sensor for my year model truck ????????? Last edited by Nvbowtie; 08-26-2003 at 09:52 PM. |
My 83 had a computer of some sort in the pass floor panel or maybe in the dash. I took it all out. Trace it down and cut it out. You wont need it with a carb that you are runnning.
Btw the way the nipple left over had a hose on it that went to the carb to sense WOT. MAP stands for M______ A- absolute P-pressue. Forgot what M is sorry!!!
You get what you pay for
![]() Join Date: Dec 1999
The thing the yellow arrow is pointing to is not a MAP sensor. It's the low vac switch for converter lockup.
Mike 1985 Chevy C-10 |
Swervin -
Mike I have a vac line running from the manifold to the tranny modulator/ Is this low vac switch for converter lockup - - a seperate source that is needed also ? |
If your tranny is a TH350C, yes, it's needed in order for the converter to lockup. If it's just the plain TH350, then no, it's not needed.
#13 | |
STILL PLAYS WITH TRUX
#14 | |
